Can I install a larger pulley on the 12v clutch? 1979 JD 111 Hydrostatic.
   / Can I install a larger pulley on the 12v clutch? 1979 JD 111 Hydrostatic. #1
svejkovat
Repowering a 1979 Hydrostatic 111 from 12hp Briggs to an 18hp 608cc Husqvarna.
The Briggs was getting long in the tooth and burning oil so I thought I'd upgrade
with a stronger engine since it was on sale for 350usd. Pressure lubed with spin off
filter blah blah. Same size dimensionally than the old Briggs. May have to drill new holes
on the deck.
Would like to take additional advantage of the added torque to spin the blades a little faster.
The easiest way would be to put a smaller pulley on the deck, but that one is already very
small. Don't want to go smaller back there. The 12v clutch pulley is twice the size and a
better candidate to make larger.
Any advice here?
   / Can I install a larger pulley on the 12v clutch? 1979 JD 111 Hydrostatic. #2
yep!. you could be making a weapon of mass destruction. if you make the blade rotate too fast, it could crack, and fly many feet!. the probability is much worse if it hits something like a rock or branch!. also, making the blade spin faster will reduce it's life!..
10ft T/A Dump Trailer (A51691)
10ft T/A Dump...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
NEW Woods Reverse Rotation 5ft Tiller (A53472)
NEW Woods Reverse...
1974 JOHN DEERE 2630 TRACTOR (A51247)
1974 JOHN DEERE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2023 JOHN DEERE XUV590M LOT IDENTIFIER 27 (A53084)
2023 JOHN DEERE...
