Can I hookup up glow plugs on a Foton 254A without a resistor?
   / Can I hookup up glow plugs on a Foton 254A without a resistor? #1
gdtractor
I can not figure out where to hook the glow plug strip to . . (it is there and a wire runs to them but not hooked up .. I don't know where to hook them up - they do work) ...
I am thinking of putting like a starter button on the dash . . do I need to reduce the + side of the battery any hooking it up for a 10 to 30 second "heat-up" ... with a resistor? my email is gdougherty@gmail.com
THanks for any advice you can give me . !!!!
Gary Dougherty (Michigan)
Foton 254A 3 cylinder diesel .... nice tractor .. it starts eventually but very hard on the battery without the glow plugs hooked up
thanks
   / Can I hookup up glow plugs on a Foton 254A without a resistor? #2
You don't need a resistor, the glow plugs are 12 volt. However, a relay is desirable. Is there a "H" position on your key switch?
   / Can I hookup up glow plugs on a Foton 254A without a resistor? #3
I have a 2009 FT254 with a Laidong KM385 engine.
If you have glow plugs you should already have the relay install. When you turn the key between run and start you should (unless different on yours ?) hear it clicking near the fuel tank.
Don't let the glow plugs ON for too long as they become hot very fast and you will shorten their life's. I do prefer to try starting after 10 sec ON then cycle again if the engine don't run.
Also pull the trottle at 1/4 before. Diesel will not start when cold, then let idle when the engine run smoother.
I have an engine heater that help a lot to reduce strain on starting system. At -20c I will never try to start my tractor using the glow plugs only.
   / Can I hookup up glow plugs on a Foton 254A without a resistor? #4
Yes you can use a simple momentary switch like a push button or spring loaded toggle.
The glow plug amperage is high however so you need an appropriate rated switch. Probably a relay is a better choice.
If there is already a relay then simply wire a momentary style switch be it toggle or push button.
As Jacques (above) suggests, no more than 10 seconds, but U can repeat after a few mins.
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
Lift Gate (A52377)
Lift Gate (A52377)
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2013 John Deere 8360R MFWD Tractor (A53342)
2013 John Deere...
