Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors??
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #1
davefr
Western Oregon
JD 1070
I converted my shop from Kerosene to Propane space heating and have about 15 gallons of surplus clean/fresh K1 Kerosene. I know Kerosene and Diesel are very closely related fuels. Can I gradually blend in some Kerosene with Diesel and use it up in my older JD's (ie 1070 and 455)? If so, what would be a safe/conservative ratio?
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #2
Yes you can, if you buy fuel in the winter in will often have kerosene blended in it already. I'd probably limit it to 20% kero but that's a guess on my part. Kero is a little "dryer" than diesel so you could blend it at a higher ratio but might want add something like 2 stroke oil.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #3
I have done that to use up extra kerosene as the salamander heater likes fresh fuel. But I only ran maybe 5% or so.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #4
Old Ford F-350 7.3 IDI diesel said in the owners manual that you could. It is out back but at 20% you would be safe in the truck.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #5
fine for winter blend ( flows better ) at up to 10 percent ... must add 2 stroke oil for lube to offset....
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #6
Yup, cut it this winter
Makes goods parts cleaner too
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #7
My winter mix is 3 gallons diesel, 2 gallons kero. If I have any space heater kerosene left in the spring, I put it in the tank a quart at a time to use up.
Will
Is there a rule of thumb for how much 2 stroke oil to add?
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #10
i think i'd go stanadyne or power service before 2 stroke oil.. if it was an on roader anyway.
2014 International DuraStar 4300 2,500 Gallon Water Truck (A44571)
2014 International...
New/Unused Pallet Forks (A44391)
New/Unused Pallet...
PALLET OF GAS CANS (A45333)
PALLET OF GAS CANS...
2007 ATOKA  PINTLE HITCH RIGGING TRAILER (A45046)
2007 ATOKA PINTLE...
2019 FORD F-250 (INOPERABLE) (A45333)
2019 FORD F-250...
2007 Chevrolet Suburban 2500 4x4 (MPV), VIN # 3GNGK26K47G305799 (A44391)
2007 Chevrolet...
