Can I bleed this gravity tilt trailer? (pic attached)
   / Can I bleed this gravity tilt trailer? (pic attached) #1
tlferrari
bobcat
I have a Big Tex 10FT gravity tilt car hailer. Its served me well these past few years but now the trailer does not stay flat to the floor when loading a car. I have to get someone to stand on it, or jack up the far end if working alone.
Are these things easy to bleed, if so does anyone know the procedure. They have access at top and bottom of the cylinder, see pic.
Thanks in advance
   / Can I bleed this gravity tilt trailer? (pic attached) #2
Usually they have a hose running between the ports. Is that how it’s been the whole time?
Yep, I bought it at about 6 months old
   / Can I bleed this gravity tilt trailer? (pic attached) #4
I'd guess this dampener is supposed to be full of hydraulic fluid and work with a hole in the piston to control motion. If that is the case, if there are no signs of an external leak then I would suspect the piston seals are bad.
20306 (A51694)
20306 (A51694)
2016 Chevrolet Tahoe 4x4 SUV (A50324)
2016 Chevrolet...
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
2017 Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
2017 Kubota...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
