Tires Can Foam Filled tires be removed?
   / Can Foam Filled tires be removed? #1
Ovaleye
Iowa
Kubota B2910
I have a b2910 with foam filled 23x8.50-14 on the front that are smooth.
Can these be removed and the rim used with a regular tires or do I have to buy a new rim? Or can these be recaped..
   / Can Foam Filled tires be removed? #2
The old tire has to be cut from the rim and it can be reused with or without foam.:thumbsup:
   / Can Foam Filled tires be removed? #3
I take it you want traction, or are the cords worn thru? Any way take a hacksaw and cut thru the old tires and peel them off? The wheels should be okay...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
JOHN DEERE TD100 10' TANDEM DISC HARROW (A51243)
JOHN DEERE TD100...
International 5488 2wd Tractor (A52128)
International 5488...
2013 Ford E350 Box Truck (A47384)
2013 Ford E350 Box...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2008 FORD F-250XL SUPER DUTY EXT CAB TRUCK (A51243)
2008 FORD F-250XL...
