Can Change Gear Range
   / Can Change Gear Range #1
Joedave
Schodack, NY
Kubota L3410
Can't Change Gear Range
I have a Kubota 3410 that has a hydrostatic transmission. It currently is is mid range and I can't switch to high or low. It appears to be locked. Anyone else have this problem or a fix?
   / Can Change Gear Range #2
Hello and welcome to TBN
I see you may have tried to change / edit your post possibly to change the title to say "Can't Change Gear Range" and you may have not been able to.
In order to change a title, just hit the EDIT button and under the edit window click on "GO ADVANCED" and it will let you change the title.
I hope this helps and I hope someone has the right info for you
   / Can Change Gear Range #3
Have you tried slightly stepping on the brake or forward/reverse pedals??? That normally works on the BX.
I did try going back and forth. Also tried engaging and disengaging 4wd and differential lock....no luck.
P.S Thanks for the head's up Yooper:
   / Can Change Gear Range #5
Some have reported jammed linkage, I would check this when all the others fail.
   / Can Change Gear Range #6
It does sound like a jammed linkage. Have you looked for physical obstructions? Get under the machine and with a strong light look for anything that may be blocking motion. Stick, rat nest, wood block, etc. Then look for signs that the linkage is bent.
Hopefully, that is it. If not, you may need to crawl inside the machine to find the issue and correct it. (think splitting it and stripping out the differential case).
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
