can a 2320 handle powering a cab heater?
   / can a 2320 handle powering a cab heater? #1
purpony
CT
JD 2440/JD 3020/JD 314/JD 345/JD 850/JD 2320
After seeing some pics of the homemade cab in the built it yourself section, has me thinking of a new summer project. I was wondering though about using a small cab heater on a 2320. I know it has a small alt and a heater draws alot of power, so i was wondering if the 2320 could handle it or not. Would be nice to plow snow with a little warmth!
   / can a 2320 handle powering a cab heater? #2
I don't think the alternator will handle an electric heater. There is a high-output alternator available though for about $380 IIRC...There are also heater's you can plumb into the coolant line also like THIS one from Curtis.
   / can a 2320 handle powering a cab heater? #3
Yep the curtis heater that is plumbed into the water pipes is the one to get.
   / can a 2320 handle powering a cab heater? #4
I have one on my 2210 that is plumbed into the coolant system. All you need is a small radiator core some fittings and a low-draw blower.
UNUSED JCT 72" HYD VIBRATORY PLATE COMPACTOR (A54757)
UNUSED JCT 72" HYD...
2003 Ford F-550 20ft Rollback Truck (A55788)
2003 Ford F-550...
KJ 7'x20' Metal Farm Driveway Gate (A53316)
KJ 7'x20' Metal...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
Survey Kit (A53316)
Survey Kit (A53316)
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
