Tires Can 4.50 x 10 tires be replaced with 12 or 13 inch
   / Can 4.50 x 10 tires be replaced with 12 or 13 inch #1
sawyerfarms
Mitsubishi D1550
I have a Mitsubishi D1550 with 4.50x10 front tires. You can't find the tires anymore was able to get a set of 4.00x10 with 4.50 tubes. Problem now is wheels keep going flat, have tried slim with no luck and patching tubes.
This tractor has a 3 lug hub and what I want to do is increase it to use a 12" or 13" standard tire for the front. Has anybody done this? My current 10" rims are rusting inside and the burs are what is causing the holes I believe, I have sanded and grinded the burs but think a standard rim would be a better solution since 10" rims are hard to find as well.
I have a "donut" 13" tire and it is the right width and fits in the space with room for turning without rubbing, just bolt patterns don't fit.
Any suggestions?
Thanks,
Scott
   / Can 4.50 x 10 tires be replaced with 12 or 13 inch #2
I had similar replacement problem and used rear lawn tractor rims to replace my MT fronts.
I cut out the old Mitsu front centers and rewelded them in place of the lawn tractor centers.
If U don't weld, take the donuts and one Mitsu rim to any weld shop and they'll do the job 4 U.
Balancing etc not a problem at tractor speeds.
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
Brush Bandit 200UC Towable Brush Chipper (A52377)
Brush Bandit 200UC...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
