Can稚 Bleed Hydraulics or Reconnect Backhoe
   / Can稚 Bleed Hydraulics or Reconnect Backhoe #1
Josann
Mahindra
New owner of emax 20. I took the backhoe off and it has been impossible to reconnect the hoses. The backhoe settled and was bumped a bit , leaving it lower than it was by about 5 inches. I have been trying to bleed the backhoe lines by loosening the hoses seatings. From what I致e read, the problem is because it settled and I should have done it on more solid ground.
Any suggestions on how to lessen the pressure and get the hoses attached? Thanks.
   / Can稚 Bleed Hydraulics or Reconnect Backhoe #2
Cycle all of the BH controls through all of their positions, including the outrigger levers.
You may have to use a small soft faced (plastic, leather, rubber) hammer to tap the ball on the ends of the hose fittings. When the pressurized one releases, there should be a burp of oil, so use a rag.
   / Can稚 Bleed Hydraulics or Reconnect Backhoe #3
Yes, bleed each cylinder hose also make sure you moved your front loader stick in all 4 directions before disconnecting hoses from the emax.
   / Can稚 Bleed Hydraulics or Reconnect Backhoe #5
Block it well before doing any suggestions above! If you don't it may settle more or even fall FAST on you!
After that you should be able to loosen one of the hose fittings and bleed some pressure to allow you to reconnect to the tractor.
All set. Thanks guys. I got better advice here than on the phone with the dealer. Will definitely be checking in here when I have a problem
2012 Volvo XC70 Wagon Sedan (A50324)
2012 Volvo XC70...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
Year: 2015 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 2 Door C... (A51692)
Year: 2015 Make...
197711 (A51244)
197711 (A51244)
2015 Freightliner M2 106 26FT Box Truck (A50323)
2015 Freightliner...
