Cam2 Promax Tractor Hydraulic Fluid.
   / Cam2 Promax Tractor Hydraulic Fluid. #1
mike35549
Bronze Member
Walker Co. Alabama
Mahindra 2538 with FEL
Anyone know anything about it what it compares to or ever use this fluid in HST tractor.
   / Cam2 Promax Tractor Hydraulic Fluid. #2
Well, how about you tell us about it? Who sells it, how did you hear about it, anything special about it? I like the Amsoil Tractor/hydraulic fluid myself. Has good temperature ratings for all season use, anti-foaming characteristics, anti-wear characteristics and long life span etc. A little on the expensive side, but you get what you pay for. Check it out. Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-3 ATH - AMSOIL Dutchy
If I could tell you all about it, I wouldn't have posted it in here.
   / Cam2 Promax Tractor Hydraulic Fluid. #4
Mikey,
Well, I'm sure that you can google it, if it's not too much effort. I see that you can type, which is good. I didn't ask you to tell me ALL about it. just how did you hear about it, or did you make the name up? Is ALL I'm asking. Whoa, Sorry to bother... Dutchy
Not sure why you replied to this thread, if you had nothing to add.
   / Cam2 Promax Tractor Hydraulic Fluid. #6
Amzoil = snake oil.
Tried it 25 years ago in a GMC Jimmy transmission.....NEVER again !!!
   / Cam2 Promax Tractor Hydraulic Fluid. #7
Amzoil = snake oil.
Started using it 1976 worked better then Conoco Polar start, have used it on and off since then, have several quarts of gear lube and 5W-50 for motorcycle and UTV.
A heck of a long way from snake oil.
   / Cam2 Promax Tractor Hydraulic Fluid. #8
Hey Fried,
you should make this your signature.
Amzoil = snake oil.
That's all I ever see you contribute.
Dutchy
   / Cam2 Promax Tractor Hydraulic Fluid. #9
Never even heard of it...which means it must be good stuff.
   / Cam2 Promax Tractor Hydraulic Fluid. #10
You're probably right! However the OP doesn't know his own tractor very well. He asks about a Hydraulic oil for an HST tractor. That's not the correct oil. It needs a tractor Hydraulic/transmission oil to be suitable in a HST tractor. I'm thinking this guy was just a troll because he couldn't be bothered to look up any info himself either. Just wants to be spoon fed. Oh well, Dutchy
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
