Cam Gear issue Kawasaki
   / Cam Gear issue Kawasaki #1
99S10
Pittsburgh
94 John Deere 855
I recently learned of this and have been searching / reading. I have a LX178 bought new in 1994. It still runs like the day I bought it. This has a Kawasaki but a vertical shaft 15hp model. It seems the only failures I read about are on the 425,455 horizontal shaft engines. Should I be concerned?
   / Cam Gear issue Kawasaki #2
I'm not familiar with that exact engine but, I have a Kawasaki Mule from that era, (mid 90's). Those year models were also notorious in their later years and extended hours of use for breaking the plastic gear off the cam shaft. The fix is a rather loud, whining, "new type" replacement cam shaft with a metal gear. They run/ran like a champ right up until they snap the gear off for no apparent reason (without hot rodding or under stress). It's a long well known problem with some of the mid 90 model water cooled Kawasaki engines that was taken care of in future models starting in the later 90's. I just replaced one not over a couple years ago. I parked it in it's regular parking spot one day and the next time I went out to start it, it wouldn't hit. Drove like a new one up until it wouldn't start, craziest thing I'd ever seen. Some may never give a problem, but many do when they start getting long in the tooth.
   / Cam Gear issue Kawasaki #3
No, on 425 & 445's only. Totally different engine.
   / Cam Gear issue Kawasaki #4
The early 345 tractors and the early 725 front mount mowers also had the plastic camshaft gear failure.
Thanks for the replies. I'll just keep running it. I just realized my little LX is the same year as the 855 I just bought.
2018 CHEVROLET 2500 SILVERADO (A52472)
2018 CHEVROLET...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
