Cable question
   / Cable question #1
gcp
Do any of you know what type cable this is, approx. what gauge it is, and if it can be used to connect two batteries together? It's pretty heavy gauge with rubber insulation but it's not copper judging from its color.
Thanks,
   / Cable question
You are so right, it's been a tiring day and I forgot to post the pics I intended. My apologies!
Please re-look at my original post.
   / Cable question #4
Not sure, but it looks like an old set of battery booster cables. The copper appears to be tarnished from weather
   / Cable question #5
It appears to be tinned copper to me, and a lot of strands so it will lay very well. as for guage.. well that is pretty hard to tell from a photo with no reference objects. Do you have a dial micrometer?..I am guessing you don't, but I would get an average of a clean cut section of the conductor and look it up in the American Wire Guage charts. Dial Micrometers are cheap, now. less than $20. They are useful for all sorts of things beside this. You should have one. 2 guage or larger would be great, 4 would be OK 6 or 8 could still be useful.. anything smaller is pretty much a waste of time for jumper cables. IMHO If you are talking about connecting batterys together, I an not sure what you mean, More input needed for a good response.. In a permanant dual battery setup, you may need a lot bigger wire. 00 maybe 000
Amazon.com: micrometer
American wire gauge - Wikipedia, the free encyclopedia
James K0UA
   / Cable question
I sure do have a micrometer but it's at the house so I'll bring it to the property with me next weekend to measure this wire for possible use.
I recently started playing around with solar pannels as back up power, and to use it on sheds around my property that don't have electricity for trickle charging equipment, lighting..... I bought 4 sets of pannels, 45 watts each, from Harbor Freight, and would like to parallel wire 3 to 4 deep cycle batteries to drive a 5KW inverter. So, if I can save some money by using wire I have laying around I'd prefer to use it rather than buy new. I like the idea of utilizing the sun for power even though the equipment needed tend to still be on the expensive side.
   / Cable question #7
Ok trying to understand what you want the wire to do.. help me out here, you have a 5KW( input?) inverter? you did not mention the voltage this operates at. We need to know the voltage to estimate the current draw, and from that we can reccomend the wire size (we also need to know the length of the wire from the battery bank to the inverter).. I sure hope your 5kw inverter does not run at 12 volts! as that would be 416 amps:shocked: I am hoping you are going to say this is a 48 volt system? And just how long are you planning running on those battery's,? I hope they are pretty big ones! Now as for the 4 sets of 45 watt panels then that is 180 watts and at 12 volts the current you are talking about to charge those batterys is about 15 amps and you could get by with number 12 wire if the length was not too long.
you do know if you are charging at a 180 watt rate, and discharging at at 5000 watt rate.. um.. you are not going to be operating at 5000 watts for long...
James K0UA
   / Cable question
James, it is a 12 volt inverter. I bought it because I thought I can eventually use it, if/when I build a house at the property. This will be a back-up system to commercial power loss, to run the refrigirator, cook top, and a few lights, if needed. I also have a 5KW PTO driven generator with 110/220volts outputs so solar won't be my only backup alternative but solar is so much more quite.
I do like the direction of this discussion, thank you! I am still trying to figure out where to place the pannels for peak performance, and the inverter for the shortest possible run between it and the batteries. I'll try to make this run no more than 6-8 feet as 00 gauge is expensive.
   / Cable question #9
Do you have your battery's yet, and what size are they.? Cook top?... I am thinking that is going to be too much. Do you have propane available in the house.? This is what we do, when running on the 5kw generator. We cook on the downstairs stove which is propane.. There are a couple of guys on here that have done the Solar off the grid thing, and have a lot of experience. Maybe we could search and benefit from them. Lets see I think one was eepete and the other was Rob-D
James K0UA
   / Cable question #10
Thanks,
Its hard to tell from the picture. It looks famaliar but canot recall where I saw it, but it was along time ago. Isn't there a label stamped on it somewhere? Looks like 100A insulation which is fine for batteries. As it is stranded wire a micrometer will not be accurate unless you have a chart for fine stranded wire which you can find in any electrician's handbook. Agree, it is weather stained copper, peel back some more insulation to get to clean material. For us non-guesser take a picture with a ruler graduated in 64ths laying alonside, we may get to an approximation + or - 1 size by using a pair of dividers for comparison. Take it to the electrical dept and try it into various wire size lugs, a snug fit is going to be close +/- a little. That stranded wire is best soldered into lugs or soldered full before clamping under a terminal screw for good connections. Take care to flux well, tin the wire first being sure to fill with solder, and do not overheat and burn the flux. Make sure the wire is clean and bright as corroded like it is you will get a high resistance connection for a set screw connection or no luck with solder. If you cannnot find bright wire under the insulation, sell it for scrap.
Ron
2003 Broce Broom RJ350 Ride-On Sweeper (A52377)
2003 Broce Broom...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
Galvanized Livestock Gates (2x Gates) (A55218)
Galvanized...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
