Cable Modem
   / Cable Modem #1
kevincook
Platinum Member
k
I finally broke down.......I've been connected for about 30 minutes now to Roadrunner. At this speed I'll be able to read more posts at TBN than ever before.
Keep posting. I need all the info I can get. Maybe I should start re-reading all of the old posts.
   / Cable Modem
I wish I could type better.
   / Cable Modem #3
I believe you have 24 hrs to correct/edit your original heading... /w3tcompact/icons/wink.gif
{I do it sometimes myself...}/w3tcompact/icons/crazy.gif
   / Cable Modem
Thanks for the tip. Now I won't look luck such a moron. Then again, maybe that won't help.
Kevin
   / Cable Modem #6
Kevin, welcome to the high speed world. Now that you have a high speed connection to the internet, dont forget, hackers have a high speed connection to you. You (and anyone on the internet) needs a firewall. I prefer a hardware solution. A router with some firewalling capability but a software solution will work as well.
   / Cable Modem #7
   / Cable Modem #8
Kevincook,
Roadrunner is great, but I'll second (or third) the idea that you need a personal firewall. Try this <A target="_blank" HREF=http://www.zonealarm.com>http://www.zonealarm.com</A>. It's free, and it was amazing to me how many "pings" it would detect during the day.
   / Cable Modem #9
DocHeb, I have the same setup running 3 cpu's at home. Just finished everythying on wed, I use the routers firewall and I have Norton 2002 virus protection on all 3 cpu's. We can share files use the same printer and all share the internet connection at the same time. I cant believe how fast DSL is,Life cant get any better/w3tcompact/icons/smile.gif
________________________________________
Take care all, Jim
   / Cable Modem
Thanks for the suggestions. I installed a network in the house a few weeks ago so I have three machines on the network. I had connected them with an old 'dumb' hub and was planning on replacing that with a router when the cable modem was installed. The IT guys at work gave me a Ravlin router to use. I need this to connect to the corporate network (some hocus pocus stuff I don't understand) and the price was right.
Since I already had a network running the installation of the cable modem was simple. I just plugged it into the hub and presto I was online. I then inserted the Ravlin router between the hub and modem and I was able to access the corporate network like I'm sitting in my office. The Ravlin router has NAT built in so all of the computers in the house get cable access.
BTW, I like the speed and I'm never going back to dial-up.
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2017 MACK CHU613 PINNACLE DAY CAB (A53843)
2017 MACK CHU613...
2025 K0520 UNUSED (5) Welded Wire Mesh Roll (A53117)
2025 K0520 UNUSED...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
