Cab Heater
   / Cab Heater #1
Ben_W
Iowa
McCormick GX45H
I'm at the point with the cab I'm building that I need to decide on how to heat it. I've read where some have brought back heat using a heater housing arrangement. Does this work well? Does it keep the windshield clear? +'s and -'s? I have also read where people have installed heaters off the engine cooling system. This is do-able since I have available ports off the water pump. Maybe someone out there has done both and can share their experience. Thanks
   / Cab Heater #2
Ben:
JC Whitney has some nice auxillary heaters. They plumb right into you water lines. I looked at the catalog and they have 12 volt blowers on them. That might be the ticket. If not, a can of STERNO will provide some heat.
I used to have an old VW Beetle and that's how I defrosted the windshield in the winter, a can of sterno. I made a holder that mounted right next to the windshield. Did a pretty good job. /forums/images/graemlins/grin.gif
Years ago, someone told me you could drink sterno if you strained it through a slice of bread. I never tried it, but that would keep you warm too. /forums/images/graemlins/smirk.gif
If I remember correctly, the vagrants refered to Sterno as "squeeze" /forums/images/graemlins/shocked.gif
   / Cab Heater #4
VWs, like Model A Fords ducted exaust heat into the cab. Then there are ceramic heaters that plug into a cigar lighter socket and blow hot air on the windshield.
   / Cab Heater #5
What he is referring to here is the exhaust it ducted through a "radiator" to extract the heat. In the VW example, it was heat that came off the engine that was ducted into the cab. Corvairs also had a similar method. All of which proved to be less than desirable. I suggest that you get the proper hot water heater to do the job. If you want to do it on the "cheap" look around for an old truck heater in the junk (now known as salvage yards) yard. If it is a 6 volt unit, you can purchase a voltage drop from Cole Hersee....
   / Cab Heater #6
Think I'd prefer a heater core with blower in the cab with a fan on the windsheild over the heat houser style.
As others have mentioned the salvage yards should provide. May even be able to find a unit that's adaptable to running a vent to the windshield.
Egon
   / Cab Heater #7
Hi...
As mentioned... Curtis makes a 15,000 BTU heater made for tractors and ties into the cooling system... I hear it works well...
..this is the one i'm getting...
Dave...
   / Cab Heater #8
Dave
$269.00 plus shipping /forums/images/graemlins/shocked.gif
The price for a warm cab. /forums/images/graemlins/grin.gif
I with you, that heater looks like it will do the job. /forums/images/graemlins/cool.gif
If I had a Cab. /forums/images/graemlins/frown.gif
   / Cab Heater #9
Sweater....... $20.00
turtle neck shirt..... $23.00
Heavy Down Coat.... $100.00
Skarf...... $5.00
Gloves....... $6.00
Thermal Underware...... $25.00
Thermal Socks....... $6.00
Insulated Boots......$45.00
Johnny Pocket hand warmers..... $15.00 each
For a Curtis Cab heater......... Priceless!!!!!!!! ...... for everything else, there is ....... the CFO !!!!!! /forums/images/graemlins/grin.gif
   / Cab Heater #10
<font color="blue"> For a Curtis Cab heater......... Priceless!!!!!!!! ...... </font>
You got that right. The heater in my cab is capable of keeping warm enough for me to not wear a jacket, even when it is -20C! /forums/images/graemlins/smile.gif
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
Wilrich Field Cultivator (A50515)
Wilrich Field...
2022 JOHN DEERE 320G WHEELED SKID STEER (A51242)
2022 JOHN DEERE...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
