Cab door pops open
   / Cab door pops open #1
Dan Lamb
MC Cloud Ca
Branson 2400h TLB/ cab
Hey gentleman ,
I know this is very minor but is so annoying, my left door latch will not hold door closed has anybody else had same problem with cab door ,still under warranty,Dan
   / Cab door pops open #2
Its ether a bad latch or it needs adjustment. Ive run into similar problems on car doors with bad catches failing to latch. Easy enough fix.
Either way it should be a dealer fix under warranty.
   / Cab door pops open #3
If just loose tighten if more than that call dealer it could save you $$$'s.
   / Cab door pops open #4
The adjustment, if that's the problem could be either the latch or the door itself. On my 6530, I replaced the door glass due to a rock strike from my drum mower and had to re adjust the door when finished for the latch to line up.
   / Cab door pops open #6
Also check the cab mounting bolts and re-torque if necessary.
Thanks for your ideas gentlemen I’ll start with your suggestions appreciate all, Dan
Update ,
The steel post that comes off the cab frame was 3/8” too short , welded a piece on the end , grinded down and
Filed , all good , thanks guys
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2016 Ford Explorer...
2015 International 4400 Cab & Chassis (A47384)
2015 International...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
2015 CATERPILLAR TL1055C TELESCOPIC FORKLIFT (A51242)
2015 CATERPILLAR...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
