cab antenna broke off.. aftermarket replacement?
   / cab antenna broke off.. aftermarket replacement? #1
mark2610d
Tennessee
L3240HSTC
Well I knew it was only a matter of time. My flexable factor cab antenna broke off. It is a screw in type. Anyone know if you can just buy the flexable tip? how much am I looking at and where can I get a aftermarket tip?
   / cab antenna broke off.. aftermarket replacement? #2
Try Radio Shack. I think they are called a "Rubber Ducky" antennna, but that just may be what my local store called it. Can't buy just the tip as far as I know but the whole thing wasn't that expensive.
   / cab antenna broke off.. aftermarket replacement? #4
Finally found a replacement for my REI radio anntena that I broke off of my two tractors, a M7060, and a L6060. Kubota wanted $85.00 but only sold the entire unit, cord and all. "The Company" ,/www.the-co.com]had one that was $12.00 plus freight of $8.00. Its is chrome, about 12" long, somewhat flexible. Fit both of my radio connections. My first try with them I did from their website and didn't fit, then Aaron went to work and sent this one to me and it works great. The part number is 210042H. Phone number 319-385-3114.
   / cab antenna broke off.. aftermarket replacement? #5
I broke the antenna on my cab. Got caught by a pine branch while plowing. My antenna is a small fiberglass rod with wire imbedded thru it. Wire was still intact so I slid a piece of heat shrink tubing over the rod and shrunk it with a heat gun. Going on 4 years now and still working. Not sure if your antenna is similar.
2010 John Deere TH Gator 6x4 Utility Cart (A42744)
2010 John Deere TH...
2016 Ford F-250 4x4 Ext. Cab Pickup Truck (A44572)
2016 Ford F-250...
PALLET OF EXTENSION CHORDS AND JUMPER CABLES (A45333)
PALLET OF...
2013 FREIGHTLINER CORONADO 122 SD (INOPERABLE) (A45333)
2013 FREIGHTLINER...
2001 P.J. MFG. CO. GOOSENECK TRAILER (A45333)
2001 P.J. MFG. CO...
2012 UTILITY VS2RA 53FT REEFER TRAILER (A43004)
2012 UTILITY VS2RA...
