C4005-DI transmission question
   / C4005-DI transmission question #1
hose6161
lone star, texas
c4005-di
Morning folks. I am getting pretty frustrated with not knowing where things are on my used tractor. My question--Where exactly is the transmission dipstick? I have found a plug on top by the gearshift plate by my feet but it is not a dipstick. I inserted a piece of wire down there and didn't see any fluid(maybe the oil level is very low or I didn't
insert it deep enough?) No problem finding the hydraulic or engine oil dipsticks. Since it is a used tractor maybe someone just stuck a regular plug there?
Any help would be appreciated.
   / C4005-DI transmission question #2
If your tractor does not have a common sump with the hyd oil lubing both the rear gears and the transmission, you probably have a plug on the side of the trans that is used to check the oil level. That is the way most standard transmissions are designed. You fill the trans up until the fluid just starts to run out the side plug. If it was me, I'd get at least an owners manual for the tractor. Good luck, Jerry ... :)
Thanks for the quick reply. I'll look for that side plug and let you know.
Found the side plug hiding behind the lefthand brake petal--muchos gracias JerryK.
   / C4005-DI transmission question #5
Won't be too happy later, if you find it is a common sump trasmission....... full of hyd/trans fluid ..... :)
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
Caterpillar 304 ECR (A50120)
Caterpillar 304...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
2017 John Deere 6195R (A50120)
2017 John Deere...
2017 Jaguar F-Pace SUV (A50324)
2017 Jaguar F-Pace...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
