C-50 loader vs. BL20(A?)
   / C-50 loader vs. BL20(A?) #1
Strongman
Southeast Michigan
Ok, I know this has been discussed before, but I think the "A" might have changed things in the BL20A. I have been leaning towards the Century so I can get the C-50 loader because of the greater lifting and breakout force (Breakout force is what you use when trying to move a rock out of the ground - right?). I thought I read in this fourm that the BL20 is the same model as the C-40 loader, made by Ansung or is it just that they are made by the same company?
When I compare the specs from the Branson website with the one on Century's, the BL20 has a rating of only 6 lbs less lift capacity at full height than the C-50 (2,094 vs. 2,100) and the breakout force 19.5" ahead of the pivot is 855 lbs GREATER on the BL20 vs. C-50 (2,755 vs 1900) and still 455 lbs more than even the C-50HL (2300). The rest of the lifting and breakout specs are not shown on the Branson website, neither is the weight of the loader.
I know everyone has said how wonderful the C-50 loader is but from these specs, it looks like the BL20 can do even more. Could this be because of the BL20A? (The website does not mention anything about the "A").
There is a Branson dealer much closer than a Century dealer, but our property is loaded with large rock and clay, so I'm thinking Breakout force would be important for me, thus that is why I was leaning towards the more heavy duty loader, but now I'm confused.
One last question for the group, did your dealer include the 50 hour service as part of your deal, or was that extra?
This group has been wonderful. It took me several days to read all the threads but it was well worth it. A lot of knowledge in those posts!
   / C-50 loader vs. BL20(A?) #2
The BL20A has a really heavy frame, similar to the C-50, and it sits about 6" closer to the front end than the BL20. It is a pedestal mount, which makes for less clutter around the engine when doing service. The closer geometry provides a leverage advantage. It will actually lift about 2600lbs, but is limited by the pressure relief to a safer limit of about 2100lbs. By the way, never mess with the pressure relief to gain more lift. 2100 lbs is plenty for a tractor that size and if you need more, you should get an even heavier machine.
   / C-50 loader vs. BL20(A?) #3
I see you are talking rocks - I spent last summer digging & moving rocks. The process I found was best:
1. Dig out with a BH BH has much stronger ripping force than loader.
2. Smaller rocks pick up with loader rock bucket & grapple.
3. Larger rocks pick up on 3pt bale fork.
4. Biggest rocks that cannot be lifted - roll/push with dozer. Pushing with loader may twist loader arms. Pushing with 3pt may shear anchor points on castings.
5. Any rocks on slope - use dozer for reduced tipping tendency. I physically removed a hilltop to take out a rock in a field.
Where the rocks weighed more than the lifting capacity of the loader but below the breakout force, not worthy of the 3pt simply get under it with the loader & drag it backwards.
Final point be aware that a light duty bucket will get bent up quickly if you use it as a pry bar.
   / C-50 loader vs. BL20(A?) #4
Hey Barry,
You bring up some good points regarding the capabilities of an ag tractor vs. an industrial machine. Ag tractors and loaders have their limitations, and are generally not designed for industrial use. They can do similar jobs, but only if used with some common sense, and with the knowledge of their limitations.
I have a Zetor Forterra (96 engine hp) with loader,both are built, bullet-proof tough, but I really push it to the limits, (and beyond), many times using it for things that really should require an industrial machine (or dozer). Being a dealer, I can do this sort of thing without it costing me too much, while allowing me to get familiar with the limitations of the equipment I sell---besides that , it's a lot of fun----a perk I enjoy by being a dealer. /forums/images/graemlins/grin.gif
dancce
Thanks Dave,
How much did the price increase from the BL20 to the BL20A?
   / C-50 loader vs. BL20(A?) #6
Dave,
how does the BL20 compare to my HL50??
jeez I always thought my HL50 was the cat's rear.. /forums/images/graemlins/cool.gif
   / C-50 loader vs. BL20(A?) #7
The "A" loaders are on the Cummin's engine machines. Price increase was modest, maybe a couple hundred bucks, more because of steel prices than the model change. It is a compliment to the C50 loader that the "A" series uses a similar really beefy mount system. Both are great loaders.
   / C-50 loader vs. BL20(A?) #8
Strongman,
Didn't mean to hijack your thread. I read your rock & clay work & recalled my first attempt digging rocks out of a field. The loader just bounced off the clay & rock.
   / C-50 loader vs. BL20(A?) #9
The Century C50HL now comes standard with "skid steer " quick-tach for the attachments. Makes it common with other makes of attachments
Chuck M.
   / C-50 loader vs. BL20(A?) #10
I have on 04 zetor/century...the FEL bucket is quick release....is this one compatible with the skid steer attchments??
that would make life very easy!
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
