Loader BX6315 Quick Attach on BX24/25 and 50 series
   / BX6315 Quick Attach on BX24/25 and 50 series #1
Tractor Nut
Manitoba, Canada
2007 BX24
There is some good discussion going aback awhile regarding the use of the Kubota quick attach(BX6315) on some of the older BXs using loaders without the A suffix on the model number. In my case I have an LA240 on a BX24.
Some of you have been using the Kubota Quick Attach for some time now on the 50 series or BX24/25s and it would be good to know if you have encounter any issues. I am looking at getting one and any info would be helpful.
   / BX6315 Quick Attach on BX24/25 and 50 series #2
Tractor Nut, I'll hop in here. I use Jery Dunn's QA on my current BX2670, had one on my last B2620, and prior BX2660. Do a search. Jery's are the schiznit. They have an incorporated 2" receiver, and flip latches to lock on the attachments. Quality is second to none. Call him up, and he'll fit you up with the right QA and ship it out.
   / BX6315 Quick Attach on BX24/25 and 50 series #3
I will second the endorsement for Jery's QA. I love it as well as the moveable forks. Great set up for the BX. One thing I do now though is use an old screwdriver to 'flip' the locking latches. Saves your thumbs from having to push hard to overcome the springs. Great quality! I routinely and quickly change from my bucket to forks because of how easy it is to do.
   / BX6315 Quick Attach on BX24/25 and 50 series #4
Great thought on the screwdriver.
I agree on JERY's QA. If I go to the 80-Series, I may see if Jery can hook me up over the SSQA. That's how much better his QA is to me. If one does not have use for other SSQA items, and the loss of weight from the SSQA can be overcome by Jery.
To the OP, Jery's QA has several benefits, and the operation and quality for the few bucks more, really will shine over the years of use over the OEM.
Thanks for the info and comments. It looks a great QA.
I have also come across the Quick Attach by Ai2/bxattachments, has anyone had experience with that one?
Ingersoll Rand 2570 Skidloader Breaker (A50774)
Ingersoll Rand...
3pt Roller (A50121)
3pt Roller (A50121)
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2023 Third Coast Equipment RA12H Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2023 Third Coast...
