Snow BX2751 & Subframe attaching to bx2360- Help, Help
   / BX2751 & Subframe attaching to bx2360- Help, Help #1
shrekbelly
guys,
i've misplaced my manual for attaching my quick hitch and subframe to bx. i don't know which i worse, misplacing the manual or having to admit that i can't remember the hand full of steps to get it done.
do i connect subframe to tractor first? try and hang subframe on frame with twisting bars into aluminum blocks on top of frame.
one picture would be worth a thousand words.
will be ordering electronic manual on monday from messicks
i hate turning 60, facing senility.
robert / shrekbelly
   / BX2751 & Subframe attaching to bx2360- Help, Help #2
Hang the quick hitch and subframe from the front bumper using the "twisting bars into aluminum blocks" and then insert the two long pins ( 3/4 x 8 5/8 and 9/16 x 8 7/16 ) thru the frame and subframe. Then tighten the "T" bolts into the aluminum blocks.
   / BX2751 & Subframe attaching to bx2360- Help, Help #3
The next step is hook up your hydrolic lines, PTO shaft and blower last. If you need more detail, let us know.
wild bill, jeff f.,
regained a bit critical thinking ability and configured as wild bill wrote. victory of sorts. it's odd that the subframe hangs from atop of the bx front frame.
thanks for your speedy reply.
merry christmas
robert a
   / BX2751 & Subframe attaching to bx2360- Help, Help #5
I used to monkey around with the PTO shaft retaining ring in the tight quarters up front.
Now, I split the shaft and leave the rear portion attached to the quick hitch. Bring the two halves together, line up the square and give it a shove!!
SET OF HOMEMADE FORKS (A51243)
SET OF HOMEMADE...
6' Skid Steer Skeleton Bucket (A50515)
6' Skid Steer...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
Land Honor Quick Attach Rock Bucket (A50514)
Land Honor Quick...
71069 (A49346)
71069 (A49346)
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
