Jay4200
Veteran Member
- Joined
- Nov 23, 2005
- Messages
- 2,054
- Location
- Hudson/Weare, NH
- Tractor
- L4200GST w/ LA680 & BX2200D w/ LA211
I just got a used BX2200 package, part of which contained a BX2750 50" front mount snowblower and quick hitch. While the tractor was in nice shape, the blower was abysmal - looked like somebody tried to suck a bowling ball though it. The fan is seriously mangled, augers not too bad but a little bent, and the overall body has a few tweaks and dents itself. I got it all apart this weekend and will begin pounding/torching/welding it back into shape. In the meantime, I figured I might as well change all of the bearings while I have it apart - I found one nice one - the rest are getting a little loose and crunchy.
SO (I told you that story so I could tell you this one) - I need bearings, but I've never seen any like this - the races aren't flat like a normal wheel bearing - they're rounded, so they fit into the tapered holders that squash them into place. They're all 1" ID, but some have extended inner race sleeves, and most come with a locking collar. I haven't called the dealer yet, but I have to imagine the mark-up by Kubota is ludicrous, and I need all 7 or 8 of them. Are these standard bearings, available at any bearing shop, or should I take out a 2nd mortgage?
Lastly, the auger drive transmission is leaking at the intake shaft seal (coming from the fan). The parts manual shows the transmission as a complete assembly. I'm sure I can get a suitable 1" seal from a bearing shop, but once I pull the transmission apart, what type of seal will I need to put the case halves back together?
Thanks!!
Thanks!!
