BX25DLB Loader Hydraulics
   / BX25DLB Loader Hydraulics #1
Fireators
BX25D-TLB
I had my BX25 loader and BH off for a week while I changed Fluids, Filters and replace Tranny Fan. Went to attach loader back on yesterday and the bucket will not curl now to lift loader up into mounting bracket. I checked the back jumper line connections and triple checked all connections for loader. Did have to push center nub on 2 female connectors coming from loader to release pressure that built up from it sitting for 1week. The lift cylinders do move to line up to cradle in bracket and hose jerk like they under pressure when I try to curl bucket down to roll loader into brackets. I did power wash bottom of tractor & tranny to get built up dirt out of cooling fins. Anyone have more ideas of cause or other things to check out? Thanks
I have got it fixed, as it was not broke. I took each connection apart for 4th time and sparyed females down with WD-40 and wiped away all oil and Q-tipped out the connectors of any discolored fluid. wiped down all male connectors and put all together again and tried hooking up loader again and this time there was no issue with operation.
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2018 Dodge Charger Passenger Car (A51694)
2018 Dodge Charger...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
