Bx25 split breaks?
   / Bx25 split breaks? #1
Smitrock5
Zanesville Ohio
Cub Cadet 129
Ones the bx 25 have the two rear breaks, or one break for both rear wheels??
Sent from my iPhone using TractorByNet
   / Bx25 split breaks? #2
One brake for both rear wheels as do all of the BX model.
   / Bx25 split breaks? #3
One brake pedal (not split brakes) is pretty common for all sub compact tractors (SCUT). In fact I can't think of any that have split brakes.
The mahindra max 25 does but they are placed right above the gas pedal which I don't understand how or when u would use them....I understand how u could make the tractor pivot if the break were on the opposite side of the hst pedal but it's not...is there a reason they are all3 on the same side?
   / Bx25 split breaks? #5
The brakes are on the right for safety reasons. You brake with your right foot when driving your car so the use of your right foot is automatic. Braking with your left foot requires a thought process and is not instinctive. The slight delay in hitting the brake in an emergency can be dangerous.
Can u give me an example of when or how u would utilize the two breaks? If it were for a better turning radius while plowing or something, I get that...just don't know why they would have split breaks if u cant use them for Thai
   / Bx25 split breaks? #7
Unless you drive with two feet. :laughing:
   / Bx25 split breaks? #8
I can use the split brakes on my L5740 by using the cruise control to go forward. My son just uses his left foot on the brakes and some can apply the HST pedal and brakes at the same time.
Split brakes are used for sharper turns, to manage traction when one wheel is slipping in lieu of locking the rear differential and to steer in low traction situations such as snow plowing or back dragging with pressure on the FEL.
I personally rarely use mine, but as the result of another thread have tried all of the above.
   / Bx25 split breaks? #9
But the Mahindra Maxx isn't really a sub compact now is it ???? ;)
   / Bx25 split breaks? #10
What is the purpose of having split breaks on the same side as the go pedal? It sure isn't safe to have both legs on one side.
As for the bx's, that brake is considered and called a parking break in the owners manual.
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
City of Lakeland (A51691)
City of Lakeland...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
