BX25 SEAT BELT FAILURE
   / BX25 SEAT BELT FAILURE #1
Artisan
Veteran Member
Monrovia, California
Kubota BX25
Of all things, you would expect a seat belt to work flawlessly.
I am beyond livid.
Today I laid my BX25 on it's side, a slow plop over and I could NOT
get the seat belt buckle to release. I am SO MAD. It simply would not
unbuckle. After several minutes I was able to get enough of my
bodys weight off the buckle, and finally it released after poking it
with a stick. SO EFFIN MAD!. I was SO CLOSE
to cutting my way out.
I weigh 240 pounds dressed.
Did I say I was MAD???
Wife will be calling corporate in the AM.
SO MAD!
   / BX25 SEAT BELT FAILURE #2
Yikes... glad you are okay and the seat belt held! I was going to make a crack like, 'how much do you weigh undressed!'. Decided that wasn't appropriate.
Seriously, was it because you couldn't 'unload' the weight on the belt? Also, how did you you lay it over? I ask only as a potential teaching experience. I have had a few very close calls. Again, glad you are okay and you were wearing your seatbelt!
   / BX25 SEAT BELT FAILURE #3
That is totally normal seatbelt operation. Corporate isn't going to help with that one. Maybe you can get the paddle style mechanism you find in planes and race cars if you want something that will release with pressure on it. Or, as you describe, carry a cutter.
Sorry to hear about the roll. Glad everyone is OK! Thank goodness you had the belt on!!
   / BX25 SEAT BELT FAILURE #4
I've never found a tractor seat belt that didn't suck. I've lucky never tested that aspect of them.
   / BX25 SEAT BELT FAILURE #5
From my aerospace experience and be it limited when it comes to seat belts... I agree! I have tested a couple involuntarily, but not in life threatening situations. I guess they worked. Design wise though seems they could be more advanced. Seat belts... IIRC originated at Indy and open wheel racing. Also side view mirrors. Someone should fact check me. But racing and other at the edge 'sports' are what propagate most of our safety initiatives. Empirical learning!
   / BX25 SEAT BELT FAILURE #6
gee i dont know my friend. we hear stories all the time about people being trapped all the time in seatbelts in cars after car flips or crashed or what have you. how would you expect a tractor to be better with seatbelts?
i just cant wear seatbelts while working around yard or customer home. i am getting in a out so many times -- just not worth it. the only time i used the seatbelt is road travel - but i dont do that anymore -- too slow.
i understand you are mad you couldn't get out - it got to be scary with a flipped tractor pushing on you or about to and you trying to get away to safety but the seatbelt not letting you. (tractor possessed maybe :p)
__Everyone who uses these tractors and who are on slopes and who
push them w/ real work NEED to carry a knife capable of cutting
that belt.
I will be affixing one, onto the ROPS where I can get at it
if it happens again. NEVER did I foresee a seat belt inop situation.
NEVER!
How? Simple. Operator Error in every aspect. They don't fall over themselves.
Not a "roll" it just plopped onto its side, real slow. Took maybe 4 full seconds.
I was carrying slash, that was piled as big as 6 school buses, Compacted,
that I feed to the fire, down hill, all off camber. Over and over and over...
Those whom remember the GRAPPLEOMATIC know
I have modified my BX, a lot. (That grapple was the best I
could have built for it BTW
) So I was carrying a GIANT grip of slash, one
pine sapling about 3" in diameter was hanging straight down on center
of the bucket and a spider web of slash was hanging out 10' easy in several
directions, wet! . Boom high, right turn on edge of fire precipice, fire on hillside,
about 3' below bottom of tires, sloped down to fire level.
The boom gets fully clocked from left to right each trip to slash pile to
compensate for off camber gravity.
I FORGOT to move BH boom full LEFT for drop, the tree hanging on center
did not allow bucket to drop
, full right turn front wheels
then the dirt gave way under right front tire. The perfect storm...
I felt it coming, no big deal just lower FEL bucket FAST NOW, BUT,
that 3" tree on center OF BUCKET? Well, it would NOT let
the bucket drop, the boom was on wrong side for better stability, and then
it happened, dirt under right front wheel gave way...
Like I said, operator error. They don't move unless a human is at the controls.
You get in a machine,you use it, and gravity, you take risks.
No speak-able damage other than my pride, that heals quick.
I sincerely am more interested in others hearing my story.
I know a defective part when I experience one. So what that I caused the
lesser issue at hand, this seat belt buckle release mechanism failure is inexcusable.
I want a whole new seat and belt system now, has anyone seen a good thread on said?
PS, remember the full cage roll bar I made?
(Yes it and the radioOmatic moved the CG, risk known...)
It came in handy, otherwise I would have had a face full of slash.
It took me a full 6 minutes and about 32 seconds to right the
BX using my new to me, CAT DC3 Series 3 you guys don't know about.
I patted myself on the back for those fast moves.
The time stamps on the pics don't lie, and that includes
pic taking time. When time permits I'll try to post up the
2 pics I took.
"It" happens... God is great.
   / BX25 SEAT BELT FAILURE #8
The seat belt operated normally. Pressure on the mechanism is suppose to keep it locked.
   / BX25 SEAT BELT FAILURE #9
x2!
Sorry to hear that you had a bugger of a time releasing the pressure at the locking mechanism, but it did exactly what it was designed to do = keep you safely in the seat during a 'roll-over' (even onto your side) situation.
Corporate (Kubota, or any other OEM for that matter) doesn't make their own seat belt latches. If you go in with an angry letter, they will simply reply with a "Thanks for your letter" letter.
2010 Freightliner M2 106 MedTec Ambulance (A46683)
2010 Freightliner...
2025 Dodge Ram 1500 Laramie 4x4 Crew Cab Pickup Truck (A46684)
2025 Dodge Ram...
2014 Bobcat S570 Skid Steer Loader (A49251)
2014 Bobcat S570...
2019 Sportsman 850 Premium H.O. AWD (A47371)
2019 Sportsman 850...
Pallet Fork Backing/Spear/Reese Hitch Combo (A47371)
Pallet Fork...
2014 FREIGHTLINER CORONADO (A48992)
2014 FREIGHTLINER...
