BX25 quick hitch attachment
   / BX25 quick hitch attachment #1
jwatt51
Wilmington,MA.
2015 Kubota B2620
I just removed my front mount snow blower from my BX25 and after I removed the quick hitch attachment,I noticed the shaft on the quick hitch was really loose. there are 2 bearing flanges on it that's attached with 2 nuts,bolts and lock washers. One flange was just floating on the shaft and the 2nd had only 1 nut,bolt and lock washer holding it on. The attachment was installed at the dealer in Oct. I'm not sure if this is a dealer install issue or if it came from Kubota like this.I wanted to let anyone know that has the front quick hitch attachment,just to check those four nuts and bolts.they each have a grease fitting on them for the bearings.I think if that last nut and bolt fell off,it could probably cause some damage to my snow blower.Next time I'm up at my dealer,I'm going to let the service dept. know about it.
2020 KUBOTA RTV...
KARCHER PRESSURE WASHER (A51244)
KARCHER PRESSURE...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
1963 Trail Mobil Tanker (A50514)
1963 Trail Mobil...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
