BX25 One Bottom?
   / BX25 One Bottom? #1
Artisan
Veteran Member
Monrovia, California
Kubota BX25
I have never pulled a plow. Is this too much for a BX25?
   / BX25 One Bottom? #2
That should pull just fine unless your dealing with something out of the ordinary.
Your biggest problem will be the ground clearance and running over the turned over soil. I do it, but its a slow bumpy ride. Especially if its fresh earth.
   / BX25 One Bottom?
Beautiful, and Thank You....
Any other comments / BUMP :D
   / BX25 One Bottom? #4
That is the same plow I used with my BX. Worked just fine. I have since moved up to a B2620 and still use the plow. I had to fix an extension to the top link so the plow works with the 2620. Happy plowing.
CASE 1150C CRAWLER DOZER (A51242)
CASE 1150C CRAWLER...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
UNUSED JCT QUICK ATTACH 74" VIBRATORY ROLLER (A51244)
UNUSED JCT QUICK...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
H & S High Capacity Hayrake (A50515)
H & S High...
20' One Trip Shipping Container (A50514)
20' One Trip...
