BX25 HST question
   / BX25 HST question #1
sxs191
I purchased a BX25 and have read allot of threads where people say that with the HST they rarely have to use the brakes. I am having to use the brakes every time I take my foot off the forward or reverse pedal. (Even on flat ground) The machine tends to want to keep it's momentum going. Is there a tensioning spring somewhere on the pedals I can adjust to correct this issue? Thanks, Scott
   / BX25 HST question #2
   / BX25 HST question
Thx. Apparently it's a common issue that looks like it can be corrected about 5% of the time, the other 95% have to learn to adapt to it.
   / BX25 HST question #5
How far are you rolling after you take your foot off the HST pedal?
   / BX25 HST question
I would compare it to putting a vehicle in neutral to stop. The distance all depends on the speed I'm traveling when I take my foot of the pedal. Unless I hit the brakes, gravity decides on how far I roll.
   / BX25 HST question #8
I couldn't handle that as hard as it is to get my foot on the brake. My BX2660doesn't stop as quickly as my BX2200 did, but it won't roll more than a foot or so depending on HI/LO selection. Initially my wife and I didn't even like it to go this far, but after using it, we like the less abrupt stops. If I need to stop quicker, which is rare, I usually just tap reverse.
PENDING SELLER CONFIRMATIONS (A45679)
PENDING SELLER...
2002 KENWORTH T600(INOPERABLE) (A48992)
2002 KENWORTH...
24in John Deere Backhoe Bucket (A49251)
24in John Deere...
INSPECTION (A48836)
INSPECTION (A48836)
2025 Swict 66in Bucket Skid Steer Attachment (A49346)
2025 Swict 66in...
2022 Club Car...
