BX25 and Rottary Cutter
   / BX25 and Rottary Cutter #1
sxs191
I have a BX25 and am thinking about getting a Rottary Cutter to clean up some ATV trails. The Trails are already established but they have the new growth in the middle between the tires. I would say the thickest growth is at the most 1". Would a BX25 be able to handle a 4' Rottary Cutter? If so, should I opt for slip clutch over ther shear pin driveline? Thanks, Scott
   / BX25 and Rottary Cutter #2
I use a 48" Land Pride rotary cutter on my BX2660 and it works really well. I routinely cut stuff you described without problems and the weight is not a problem.
I prefer slip clutch over shear pin.
   / BX25 and Rottary Cutter #3
We have the Hawkline/International 4 ft for $795 with shear pin and $920 with slip clutch + modest shipping. Ken Sweet
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2013 Ford F-250 Ext. Cab and Chassis Truck (A50323)
2013 Ford F-250...
2020 Kubota BX2380 (A50120)
2020 Kubota BX2380...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
