Bx24
   / Bx24 #1
Sanman44
Milford pa
Bx24
My bx24 backhoe an front loader will not operate what could it be I hear a hi pitch sound
   / Bx24 #2
The squeal is most likely the PRV (pressure relief valve) opening. Undo, clean, and reconnect the hoses the feed the backhoe as they are probably uncoupled just enough to block the hydraulic flow. If you continue to operate like this, you can overheat your fluid and/or cause damage to your pump.
One other thing to check, make sure the 3PH lever is not in the full up position.
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
John Deere 455G Loader (A48837)
John Deere 455G...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2006 Volvo VNL (A52128)
2006 Volvo VNL...
2020 CATERPILLAR 299D3XE SKID STEER (A51242)
2020 CATERPILLAR...
