BX24 won't shut off
   / BX24 won't shut off #1
Cass
Came out one morning and heard the fuel pump on the tractor ticking away even with the key switch off. When I tried to start the tractor,battery was almost dead. Started the tractor with a boost ,ran for awhile then could not shut off the tractor. Had to engage the PTO with empty seat to shut off the tractor. Called service dept and was told to check key switch. Sure enough,when I took the switch apart,there was water and corrosion inside. Dried out,sandpapered contacts,reconnected switch and tractor was good as new. Just a heads up if this happens to you.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
71053 (A49346)
71053 (A49346)
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
1986 John Deere 772B Articulated Motor Grader (A49461)
1986 John Deere...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
