BX24 Weight with FEL & BH? & Towing
   / BX24 Weight with FEL & BH? & Towing #1
Torrak
Washington State
Kubota BX24
Hi,
Tried to do a search for this answer, but getting PHP errors so I figured I would just ask.
What is the weight of the BX24 with FEL and BH attached? Kubota's site is claiming 1542, but I am not sure if that is simply the tractor or everything.
Also, I drive a Jeep Unlimited with a towing capacity of 3500 lbs. Say I have a 1500lb trailer and the BX24 is actually 1542 for a total of 3042 lbs. Would I be able to tow this tractor on a 16' trailer (if said trailer is 1500lbs) safely? (if it has electric brakes)
Thanks all!
Joe
   / BX24 Weight with FEL & BH? & Towing #2
I tow my BX2350 with FEL, MMM, and bagger with our Suburban and you can definitely tell it's back there. I suppose it depends on how far you're going, etc., but I'm not sure I'd push your Jeep -- many bad accidents occur due to over-burdened tow vehicles.
   / BX24 Weight with FEL & BH? & Towing #3
I think there is a plate on the Rops that says somthing about it weighing 2995lbs, if i seen it correctly. it was on the left side down low i think,,
   / BX24 Weight with FEL & BH? & Towing #4
</font><font color="blue" class="small">( What is the weight of the BX24 with FEL and BH attached? Kubota's site is claiming 1542, but I am not sure if that is simply the tractor or everything.)</font>
I have a BX2200 that weighs 1300 Lbs alone. The loader is 430 Lbs and I can't find my info on my Woods BH6000 right now but I'm sure it was around 700 Lbs. So that would make your package closer to 2500 Lbs. I'd say be real careful pulling that with your Jeep! /forums/images/graemlins/crazy.gif
   / BX24 Weight with FEL & BH? & Towing #5
The BX24 Tractor weighs in at 1542 lbs.I did ask the dealer when I was there the other day.I has a more heavy duty frame than the BX2350 because of the BH.The BX24 BH weighs in at 617 lbs.,and I cannot find out what the FEL weighs.I'm guessing about 5-6 hundred lbs. It will be pushing about 2900 lbs or so. That's heavy for a small tractor.
My question is will the BH dig well in hard dirt? I;m thinking of getting a BX24 by the end of the year and was wondering.
Donny
Thanks for the replies all. Sounds like it would be too heavy to pull with the Jeep shy of using an unsafe lightweight trailer.
Donny, the backhoe does great! We used it this weekend in my "rock patch" to dig out rocks from the sizes of tennis balls to the size of lawn chairs. You just gotta keep in mind it isn't a piece of large equipment so sometimes you have to back out and try a different approach on the larger stuff.
Joe
   / BX24 Weight with FEL & BH? & Towing #7
Torrak,
I'm a tractor newbie/wannabe and the towing part of the whole equation interests me greatly. I just bought an aluminum trailer to maximize the towing load of my 5,000 lb limited truck. The trailer weighs 620 lb (6.5'x12' deck) and is rated for 3500 lb with the electric brake. A 16' would be about 1000 lbs. That would put you just over your limit, but aluminum is more expensive though cheaper than a new vehicle unless that's where you want to go.
Jeff
2014 TREMCAR PNEUMATIC TRAILER (A45333)
2014 TREMCAR...
2011 MAGNUM PRODUCTS LIGHT TOWER (A45046)
2011 MAGNUM...
DEWALT SDS MAX HAMMER (A45333)
DEWALT SDS MAX...
15 YARD HOOK LIFT ROLL OFF CONTAINER (A45046)
15 YARD HOOK LIFT...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A43004)
2019 INTERNATIONAL...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A44789)
2010 Gleaner 9250...
