If you go to this page and click on "Photo Gallery", you will see a
B26 with bh off, and 3ph on, using a variety of 3ph implements.
Kubota Tractor Corporation - B26
I maintain 5 acres with a
BX2200. My 40" heavy duty Gearmore brush hog cuts 2" dia saplings without slowing down. Do not be certain that a BX is too small. Maybe it is and maybe it isn't. Search the archives and you will see
BX22, 23, 24, and 25 digging up some sizeable stumps. Look through this thread in which blackmajicwoman uses a Woods BH6000 backhoe on a
BX1500 to accomplish all sorts of tasks.
http://www.tractorbynet.com/forums/kubota-owning-operating/54527-bx1500-woods-bh6000.html
This
BX1500/BH6000 combo is impressive and a
BX24 or 25 will certainly outperform that. If you just need some really serious stumps pulled one time, and just need to maintain this one property after that, you could rent a bigger tractor and then the BX should work fine for the rest of your needs. This is assuming you are not talking about a real farm or ranch. Then you really do need greater capacity.
Be aware that the
BX24 went through a series of modifications. The first ones were loaded with plastic. The floorboard is attached to, and supported by, the fender. Stepping on the floorboard caused numerous fenders to break. Later models were still plastic, but with some reinforcment ribbing on the back. The last of them went back to metal. The first BX24s had the old style seat, and the last ones had the new seat. There was something similar to a recall on the fender. For a period of time Kubota replaced the first plastic fender with the reinforced one for free. You might want to check on which of the 3 fenders is on the model you're interested in. You can find tons of info re. the fender and seat by searching the archives.
This is just my opinion: a BX might meet your needs. If I were looking at a B series, I would look at a
B3200. The
B3030 is also a good tractor, but the MMM for it is not suspended. The MMM on the
B3200 is. I personally would look at any of the regular B series as opposed to a
B26, but that is just my own preference.
Maybe it would help if you describe how many stumps and what size, tell us how many acres you have, if you will have lawn, pasture, cut and transport logs, do landscaping, etc. I think we could give much better advice if you could give a higher degree of specificity regarding your property and goals.
