BX24 No start (alternator problem)
   / BX24 No start (alternator problem) #1
St-Albert, On
Kubota Bx 24 tlb
Hi to all, for the past week I noticed that my BX24 was cranking over much slower than usual. Tonight when I went to start my toy it wouldn't start. After looking things over I noticed that the main lead at the alternator was rusted and loose. I cleand up the lead, tighted it up and it started to charge again. I was very surprised to see rust on the wireing , my bota sleeps in the shop. So for all you guys out there lucky enough to own one of those babies, should take two minutes to look at your alternator before you get stuck out in the boonies!!
   / BX24 No start (alternator problem) #2
I couldn't get mine to start either, so I pulled the screen off, and the negative terminal fell out. It was never put on the battery!
Sadly that wasn't my problem, the PTO engagement lever was, a few shakes and it started. I spent about 3 hours trying to figure that one out.
   / BX24 No start (alternator problem) #3
I wish that thing weren't so sensitive. And I also wish it were on the same side of the loader stick, since I just about always get off the tractor on the other side and occassionally bump the PTO lever. :)
   / BX24 No start (alternator problem) #4
Put a dab of vasolene or chassie grease on the 'lectrical connection.. it will help prevent corrosion.. etc..
Soundguy
   / BX24 No start (alternator problem) #5
I'd like to get a little clarification on this..:)
The main lead should be copper or tinned copper or heaven forbid aluminum, none of which rust.:confused:
Was it perhaps the stud on the back of the alternator that was rusted?
Thanks.
   / BX24 No start (alternator problem) #6
I had similar problem with my BX23. It ran fine for six months, then battery finally had enough. Turned-out the alternator wire wasn't attached.
Dealer sent a mobile mechanic to fix it (10 minutes) and gave me a new battery too.
Russell in Texas
CATERPILLAR 299D SKID STEER (A51242)
CATERPILLAR 299D...
Terms and Conditions (A47384)
Terms and...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
