My BX24 (270 hours) has developed an intermittent engine power loss. The engine revs suddenly drop, say from 2800 during normal operation, down to below 1500 and it seems the engine is about to stall. If I let up on the hydrostatic pedal, and/or disengage the mower if it was running, the engine recovers over 10 seconds or so. But the whole thing recurs a minute or two later. It seems to happen most frequently under load - say operating the mower, or going up a 10 degree slope with no implements active.
Things I've eliminated: air filter (changed just 50 hours ago, checked and it's clear); a plugged fuel tank vent cap (symptom happens even with fuel cap off). And the fuel tank is full. I don't think it's the seat switch because it happens even on level pavement with no bouncing, and I'm plenty heavy
I'm thinking it could be the fuel filter or a plugged fuel line. But there seem to be two fuel filters -- one under the chassis that's the devil to get at, and one on the engine next to the injection pump. Which do you think is more likely to plug up? Or do you have other suggestions? Thanks in advance for any help you can give.
