BX24 Hydraulic couplers
   / BX24 Hydraulic couplers #1
Inky05
Bronze Member
Kubota BX24, Kubota L260
Does anyone know if they are "Industrial" interchange or "Safeway" interchange... or are they special?
   / BX24 Hydraulic couplers #2
If they are the same as what is used on the BX1850 they are an "Industrial" interchange. I am fairly sure mine had a brand name and part number on them.
   / BX24 Hydraulic couplers #3
its a snaptite brand couplers. You are not gonna find it at your local TSC store if you are asking- I checked. MY local hydraulic shop told me he can get matching sets that would be cheaper but I am hesitant to use anything else but snaptite.
Thanks guys... did a search and best I can figure they are 1/4" ISO 7241-1 B series.
(Which is indeed "Industrial" interchange")
Now for the next questions...
I want to add T & T on the BX24. I am assuming I can use a two spool tandem center Joystick valve(like a Loader valve). Use a hose with a female coupling for the "P" port and a hose with a male coupler on the "T" port and connect them where I would connect the BH hoses... since the BH won't be on when I'm using the T & T. A & B of one spool to the Toplink and A & B of the other to the tilt cylinder.
Is this correct?
If I use a loader valve, which cylinder (if any) should have the "float" ?
   / BX24 Hydraulic couplers #6
Inky let me know if you go the route of the BH hoses. I've been thinking about doing that exact same thing just haven't acted on it yet.
Will do...
It seems logical that it will work!
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
Komatsu 330 Excavator (A51573)
Komatsu 330...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
