bx24 fuel filter change
   / bx24 fuel filter change #1
engchg01
bx24 kubota
Hello everyone, I have a bx24 with about 200 hours on it. The other day it would not start and after a quick inspection it was apparant that there was no fuel. I looked on the forum and saw some discussion on changing the fuel filters. I replaced them today and it fired right up. The filter on the bottom was very accessible and took maybe 10 minutes to change. I dont have any skid plates on my tractor. The one on the side of the engine is a little more challenging. I used a quarter in ratchet and 10 mil socket to remove the filter clamp. I took the fuel line off the injector pump and cut the tie wrap holding the fuel line to a wire harness. I pulled the filter and line down and out of the bottom of the tractor and replace the filter. I put new clamps on as the original ones seemed to be brittle and a couple of them broke.. I fished the line and filter back up and put the hose back on the pump. I would say this way takes about 20 minutes or so..
Reinco TM730 Straw Blower (RUNS) (A50774)
Reinco TM730 Straw...
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
John Deere 6420 (A50120)
John Deere 6420...
1994 Mack CH613 (A50120)
1994 Mack CH613...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2011 Mack CXU612 T/A Roll-Off Truck (A50323)
2011 Mack CXU612...
