Tires BX24 dirt/mud tires - turf or r4 or combo?
   / BX24 dirt/mud tires - turf or r4 or combo? #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
I have turfs now that are not loaded for my grass. Would it make sense to get R4s that are filled for better traction on mud or dirt? I think if I do this I might only get rears. Thoughts?
   / BX24 dirt/mud tires - turf or r4 or combo? #2
If your planning on buying an extra set of tires and rims. I would go with the bar or ag tires for mud. R4's are the all around tire that is what I have on mine and they work very well. If your are just going to have just one set of rims I would go with R4's best of both worlds.
   / BX24 dirt/mud tires - turf or r4 or combo? #3
You can't run turfs on one end and R4s on the other.
   / BX24 dirt/mud tires - turf or r4 or combo? #4
There are some here that says r4 and turfs don't have the same radius therefore when in 4 wheel drive with mixed tires, it could damage the hydro tranny. I currently have turfs, and I do find that they do clog up in the deep mud, but does fine with light mud. I have filled the tires with liquid ballast and they really to help in the mud. Add chains , you would have better traction then r4 alone. just my 2 cents.
   / BX24 dirt/mud tires - turf or r4 or combo? #5
I priced a set of rims and tires, and it was less money than I was expecting, less than $400 if I recall.
   / BX24 dirt/mud tires - turf or r4 or combo? #6
You can't mix tires.
* If your are just going to have just one set of rims I would go with R4's best of both worlds.
*I say worst of both worlds not best.
why cant the two different types of tires be mixed? I thought this was now an option from the factory on the new Bs. Obviously the fronts are always much smaller
   / BX24 dirt/mud tires - turf or r4 or combo? #8
Because it will mess up the rialto between fronts and rears causing drive train damage.
There was a thread about this just the other day.
   / BX24 dirt/mud tires - turf or r4 or combo? #9
I bought my BX2200 with turfs on one set of wheels and ags on another. The turfs have been sitting in the crawlspace for 8 years. The turfs are useless when doing ground engagement work, like ripping hard clay with a sub-soiler. On the other hand, the ags do no damage at all to my lawn, even when wet. It is a no brainer: ags stay on all the time. Forget turfs, forget industrials, ags are the only tire to consider in my book.
   / BX24 dirt/mud tires - turf or r4 or combo? #10
LB is correct, it is not that the different types of tread make a difference, it is the diameter that is important. Without the proper diameter ratio front to rear the drive train will bind which can do bad things.
It would seem that a set of chains would be the cheapest and easiest way to gain traction. I would think changing tires between mowings would get very old.
MarkV
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2014 Jeep Compass Multipurpose Vehicle (MPV), (A51694)
2014 Jeep Compass...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
