fishpick
Platinum Member
So - simple question... BX24 - about 25 hrs on it... love it... I've got enough experience with the BH to know that it's not super fast when engaging both levers to do boom/dipperstick or swing/bucket work - but it's fast enough... so here's the issue tonight that has me concerned something is wrong with my BH.
Tonight I'm outside digging a trench across the gravel driveway with the BH and all was going fine - then I tried to extend the bucket at the same time I pulled back on the boom lever to lift the boom... bucket extended and then the boom moved... It seems if I move the bucket and the boom raise/lower at the same time - the bucket goes fine - boom will not raise (lowers, but the manner looks like gravity more than hyro).
So - question is - should the boom be able to raise at the same time the bucket is curling or extending? Dipper stick does, boom will swing... just will not raise with the bucket moving - stop moving the bucket the boom snaps right up fine. Sounds bad to me.
Also relevant - I DID move all the hydro cylinders on the BH and the loader through ALL ranges of motion a couple of times to ensure that there wasn't air anywhere in the system.
