jfhall
I'm hoping somebody has some ideas where to start. For most of last winter I had issues with it running in the winter, even when the temperature wasn't overly cold (15 - 20 degrees even). We did have some cold days last year previous to when the problems started so I assumed the issue to be diesel gelling issues as I didn't treat the fuel. It does have a block heater so the fix was to plug it in for a few hours and try again. Just frustrating since I want to do what I want to do now, not in 6 hours!
I had a full service done on it near the end of the winter, fuel filters replaced, etc. and spring came. Used it all spring/summer/fall of course with no issues. Cold weather started to come so I picked up fresh fuel, treated it and got ready for winter. I wake up this morning to 12" of snow. It's been cold lately (10 degrees), and am having issues this morning with it again. = stranded at home for the next 6 hours!
Symptoms (same as last year):
- I turn the key, warm the plugs for 20 secs and tractor starts fine
- Idles rough for 5 - 10 secs then smoothens out and sounds fine (I leave it idling low to warm up)
- 3-5 minutes later (still just at an idle) it starts to run rough then stalls
- Now won't start at all without being on the block heater for half a day
This is year 3 of having the tractor. Never had these issues through year one. Had a B7610 previously and never had issues with it either. The obvious answer is gelling but why does it run for minutes first. I have also treated the fuel. Last year at one point I pulled the injectors and cranked it over to make sure I was getting fuel and I was.
Do others have issues with their BX tractors? I saw one other post hear wear the symptoms were similar but no answer (http://www.tractorbynet.com/forums/...ng/161210-bx2360-glow-plugs-cold-weather.html).
Just very frustrated - need a reliable tractor when I need it, not 6 hours later.
Thanks for the ideas
