BX2360 Dies when engaging PTO or go pedal
   / BX2360 Dies when engaging PTO or go pedal #1
AFChief
Uhg! Halfway through the lawn and my BX2360 just dies. The engine is running fine when not under a load. Anytime I engage the PTO (mid, running the MMM) or try to move via the pedal, the engine bogs out. I checked the trans fluid and it's good. Moving the three point up and down doesn't effect the engine, just PTO or Hydrostatic. I can shut it off for a few minutes and start it up and it will be normal for a minute, then dies. Any ideas?:confused:
   / BX2360 Dies when engaging PTO or go pedal #2
sounds like what my BX24 would do if my butt wasn't on the seat.
have you checked the seat switches, and wiring ?
Pete
   / BX2360 Dies when engaging PTO or go pedal #3
My bx25 does that when I am sitting on top of my hill using the backhoe and then try to move the tractor. I got put it in high range and drive a few feet then I can use low range again.
   / BX2360 Dies when engaging PTO or go pedal #4
i second the seat switch
You guys called it. I refueled before starting and had flipped the seat up to clean up some spill. Crushed the harness in two places when I locked it back down. Wire was shorting to the frame causing erratic release of the switch, hence the reaction to PTO and Hydrostatic.:ashamed:
   / BX2360 Dies when engaging PTO or go pedal #7
glad you solved it........now get back to work :laughing:
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2017 Volkswagen Jetta Sedan (A50324)
2017 Volkswagen...
Swict 66" Skidloader Bucket (A50774)
Swict 66"...
We do NOT accept credit cards as payment. (A50121)
We do NOT accept...
John Deere 915 Flex Head (A50774)
John Deere 915...
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
