BX2360 and Brush Grubber BG08
   / BX2360 and Brush Grubber BG08 #1
D902 BX PILOT
BX2360
guys,
need to figure out a way to remove a about 4 dozen small trees (2 to 4" in diameter). have a bx2360 and have found a BG08 at bailey's online.
has anyone used this device, with a similar sized subcompact tractor?
regards, D902 BX Pilot
   / BX2360 and Brush Grubber BG08 #2
Rent a skidsteer for 1/2 a day and take them out in a few passes. UNLESS you will need the attachment at a later date.
   / BX2360 and Brush Grubber BG08 #3
How about something like this. If you can weld, it would cost about $100. I believe one of the TBN guys built this. Just build it to fit your tractor.
gentlemen,
the BG08 is @$80.00. if my bx doesn't have the courage, i can attach it to a Ford F150 or Honda Pilot.
thanks for your responses. D902
   / BX2360 and Brush Grubber BG08 #5
Just pick up some chain. Wrap the chain around the tree a few wraps than hitch to the draw bar on you BX or you truck hitch and pull them out. The chain will be cheaper and works just as well.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
434669 (A48836)
434669 (A48836)
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
