BX2360 Air Ride Seat
   / BX2360 Air Ride Seat #2
I was thinking the same thing while mowing over roots a couple of days ago. A air ride seat would make it a lot more smoother. I don't know of any for the BX but if there was I would diffenently look into it.
   / BX2360 Air Ride Seat #3
LOL. I keep thinking of Oliver Douglas in the opening sequence of "Green Acres". He tractors by, bouncing 12". Might be more fun with Eva Gabor in your lap... :)
Would think an air seat might make keeping the hydro pedal steady a little difficult. Guess you could keep your heel on the deck. Never seen an air seat that would fit a BX though.
   / BX2360 Air Ride Seat #4
Is it possible to get an air ride seat for the BX2360?
The air bags used for air ride seats are very large in size and you would have trouble with reaching the pedals and the seats are very very expensive and would require the use of an onboard compressor and may make the riude much worse because of the short wheel base of the tractor-essentailly turning it into a trampolene.
Perhaps you shold look into having the rear tires loaded as that also works very well to soften the ride-the air in the rear tires is simply acting as a balloon and reacting to the speed of travel during work.
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
ECHO PB-580 H/T GAS BACKPACK BLOWER (A51248)
ECHO PB-580 H/T...
2003 SUZUKI VINSON 500 ATV QUAD RUNNER (A51247)
2003 SUZUKI VINSON...
