Rotary Cutter Bx2350 with woods hc 54
   / Bx2350 with woods hc 54 #1
Fi-Q
Well... permanent adresses is Bonaventure, Eastern
White LT 18hp B&S old beater
I did post this already but I think I should have post it here instead of owninf/operating.
Hi all, The tractor is not mine, it's my dad. But I am alowed to use as long as I pay fuel and help him with maintenance fees . So we are looking for a rotary cutter.
Our kubota dealer wants to sell us a 48 in Titan. And he also have a 48 in thrifty from last year he said he could make a deal on it. But it'S roughly in the 1300$ for both (But I do think I can do an aggressive offer on the last year thrifty brand as he is not stocking them anymore).
But, I eventually want to get my own tractor, and I plan on going with a lger unit than a bx. So far, (I can change my mind a 100 times) I think either a B2920 or a MAhindra max 28 would be my kind of tractor (Ok, lets not start a tractor debate...). So I would like to optimize the brush cutter size for my eventually bigger tractor. I think a 5 foot would be to big for the bx. But I too think a 48 would be too small for a B2920.
So after searching a lot, I found the woods HC 54, wich I think would be a good compromise in sizing. I found some at 1250$ not too far from home (500km, I need to check with them on a shipping quote) What do you think ? Is the 54 would be too big ? The bx have a FEL that can help to balance the tractor. The cutter would be mostly use to maintain a small field that is not beign farm yet and some area on the property where it is too rough to mow. The land is mostly flat ground.
As anyone run a 54in or even a 60in comfortably on a bx2350 ? Or any similar size sub compact tractor ?
   / Bx2350 with woods hc 54 #2
I run that same cutter on a B2620. I previously owned a BX 2200. I think the BX would have enough power in light/moderate grass cutting for the 54, but 2 things I would be concerned about-the first is the weight of the unit. I don't have specs handy but I belive the weight is somewhere around 500lbs-quite a load for the BX. The second thing to think about is clearance-the BX is limited on the amount the 3pt hitch can raise an implement.
Will
Will,
Your about right. It weight 487 lbs.... Quite a load for a bx, I agree.....
I would like to give it a try..... I'll keep looking for some feed back
I ve check and there is only 44 lbs diffrence between the HC48 and the HC54.... So if i decide to go that route, I will def get the 54....
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
1967 Ford F100 (A47384)
1967 Ford F100...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
JOHN DEERE 3032E TRACTOR (A51243)
JOHN DEERE 3032E...
CATERPILLAR SKID STEER PALLET FORKS MAST (A51244)
CATERPILLAR SKID...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
