Bx2350 vs b7610
   / Bx2350 vs b7610 #1
reupop
Went to the local dealer and got pricing on both units with a FEL and 54" mower. The difference is about 1,555. I noticed that the B w/FEL will not lift as much as the BX. Is this due to CoG. The BX is at 6.5 and B at 12 inches ground clearance. Can't decide which one to get. Have 5.5 acres and will cut about 2 to 3 ac's. Will have 2 horses in a barn/stable. Question is which makes more sense to get.
Reuben
   / Bx2350 vs b7610 #2
my buddy has a bx and i have a b7510. there is no way the bx will lift more.
i bush hog with mine and the b series is a much better choice for crossing rugged ground.
i would get a b without question. don't overlook the 7510. i figured it would be underpowered. it is not. i have been very impressed with the machine.
i originally was looking for a 7800 or 7610 when i came across a great deal on the 7510.
   / Bx2350 vs b7610 #3
BX2350 Lifts 500mm (19.7 Inches) in front of bucket:
With LA 203----408 LBS.
With LA 243----518 LBS.
B7610 Lifts 500mm (19.7 Inches) in front of bucket:
With LA 272----495 LBS.
With LA 302----555 LBS.
With LA 352----670 LBS.
   / Bx2350 vs b7610
I couldn't figure it out. The booklet from the dealer shows
Bx
FL La203 617 lbs
FL La243 745 lbs
B
FL La302FL-1 550 lbs
FL La352FL-1 670 lbs
To me it not a big deal I looking for the best value overall. The price was
BX at 12000 and B at 13251 both w/FEL only. Plan to get a 54" mower.
   / Bx2350 vs b7610 #5
The figures for the BX that you see are at pivot pins.
Here are the figures for the B7510-B7610 at pivot points.
LA 272----685 LBS.
LA 302----770 LBS.
LA 352----925 LBS.
To get true lift capicity look at lift Capicity 500mm (19.7 Inches forward of Pivot Pin).
   / Bx2350 vs b7610 #6
Had a BX 2200 which is about the same as a BX 2350 and I sold it to get a B7500 which is about the same as a B7510.
The main reason I sold the BX 2200 is not enough ground clearance and kept getting it stuck from the transaxle bottoming out in soft soil.
If you are going to work in woods or soft soil get a B7510 or B7610.
   / Bx2350 vs b7610 #7
The B7510 power comes on much sooner then the BX2350 engine.
B7510----21 Horse Power @ 2600 RPM.
BX2350----23 Horse Power @ 3200 RPM.
My B7500 seems much stronger then the BX2200 ever was.
The reason is torque.
The engine touque band is much lower and broader on the B7500 and B7510 then the BX tractors.
Reason the B7500 and B7510 engines have more torque is Larger Cubic Inch Displacement.
The BX tractors try getting the horse power out of a smaller cubic displacement engine by spinning it at higher RPM's.
   / Bx2350 vs b7610 #8
I would have to say that the 7610 may give you more flexibility for future implements and uses due to the larger stature of the 7610. If you don't care about that or anything else, I'd get the BX and an extra implement or 2 with the $1555. I'm kindof surprised the price is so close.
Agree with the revised lift specs in this thread.
   / Bx2350 vs b7610 #9
The B7510 is very close to the same price as a BX2350.
I believe within $1000.00
   / Bx2350 vs b7610 #10
The thing you have to figure out is what are you going to use it for.
I made a mistake with my first Kubota and I try to help others not to make the same mistake.
BX series tractors are good tractors but they have limitations in soft soil with low ground clearance.
All tractors have limitations. Just try to make the best decision the first time.
2000 GMC 3500 Bucket Truck (A47384)
2000 GMC 3500...
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
Electric Mobility Scooter (A51694)
Electric Mobility...
2007 BMW 750Li (A50324)
2007 BMW 750Li...
2014 CATERPILLAR 740B OFF ROAD DUMP (A51242)
2014 CATERPILLAR...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
