Oil & Fuel BX2350 Running Rough and Smoking
   / BX2350 Running Rough and Smoking #1
GA06BX2350
Oxford, GA
2006 Kubota BX2350
First of all I would like to thank you guys for reading this post. Earlier this summer I got a bit careless on my BX2350. I didn't lock down the ballast properly, and laid my tractor on its side. I was able to switch if off after 10 seconds or so. After an hour with a winch and a tree, I up righted it. I let it sit for a few hours and then I started it up (a hard start), drove it to the shed. It smoked the whole way. After a few days I started it up again, it ran rough and continued to smoke. Since that day I've run a tank of fuel through it. It always starts off running rough at low RPM and smoking. At higher RPM (2300) it smooths somewhat, but still nowhere near where it should be and it still smokes. After 1/2 hour or so the smoke decreases, but doesn't disappear completely. At that point and time, if I decrease the RPM the smoke is almost entirely gone. It starts smoking again if you crank the RPM up again. Although it never runs 100%, there are times after it warms up that it seems to want to try. It also never completely stops smoking. I've tried draining the tank and flushing with fresh diesel, I've changed filters a couple of times, and I've also checked to see fuel coming out of the fuel lines at the injectors. Any suggestions on my next step? Injectors? Injector pump? I'm at a loss where to go from here. Thanks in advance for your help.
John
   / BX2350 Running Rough and Smoking #2
The recommended procedure once a diesel engine has been tipped is to loosen either the glow plugs or injectors before turning the engine over, to insure that no fluid is present, on top of the pistons. Diesel engines are high compression machines and liquid does not compress so something has to give. The worst that can happen if you rotate a hydro locked engine is to bend the connecting rods and or damage the pistons and or piston rings. Even the torque of a starter motor will be enough to do the damage. Only a small amount of liquid need be present to raise the pressure in the compressed cylinder to dangerous levels.
The most basic test for a diesel engine, since it is basically an air compressor, is to do a compression check on each cylinder. Each cylinder must be within tolerance for the specified pressure or fuel will not ignite properly since there is no ignition system. Compression creates heat to fire off the injector spray and it must be high enough to fully combust the fuel. Do this, or have it done and you will either get the bad news, or eliminate the likelihood of any severe damage and move on to other potential issues.
Sorry to jump to this possibility but a compression test will be like getting an X Ray on a damaged limb to find out if the bone is broken or you just have a bad sprain. Here's hoping your numbers are high and some silly thing is causing your machine to smoke and not deliver full power. A compression test is inexpensive either to do yourself with the proper gage or to have a qualified mechanic perform.
Recoveryhill,
Thanks for the input. Good news, bad news, progress is good. Of course I prefer good news. :) I did a bit of calling around to a local shop before starting it that first time they reported that it shouldn't be a problem to start is. Based on your input and other input I've gotten, that initial advice sounds like it may have been bad. Oh well! I'll stop by the parts store on the way home to see if I can get a compression tester. I've never used a compression tester and hope never to have a reason to do so again, so do you think an inexpensive one from Harbor Freight would suffice for a few uses. I know they are cheap, but I'm not sure how accurate I really need for this test. Thanks again for your help.
John
Ok. I picked up a compression tester at Harbor Freight that supposedly has an adapter for a Kubota. Now, I have a stupid question. How exactly do I do a compression test? My guess would be to:
1) remove all three injectors so that there's no chance the engine will try to run on only two cyclinders making things worse
2) select the correct adapter and place tester in injector hole
3) unplug the fuel pump so that fuel isn't flowing all over the engine
4) using key, turn engine over slowly to see if pressure is created and maintained in the cylinder
  • Any suggestions, corrections, etc?
  • If I remove the lines from the injectors, how do I remove any air in the line?
  • Is there a way to test the injectors?
John
   / BX2350 Running Rough and Smoking #5
Disable the fuel solenoid to insure no fuel enters cylinders if you are using the glow plug position for the gauge. If you are using the injector position, also disarm the fuel solenoid to prevent injector spray while testing. Remove all glow plugs, or injectors depending on where you are mounting the gauge. Take extreme care not to cross thread the gauge when attaching.
The engine should be warm before the test as this will result in higher readings. Crank the engine over with the starter until the pressure in each cylinder peaks, and record the value.
There is a target pressure for a new engine, a minimum pressure and a maximum allowable pressure differential between cylinders.
Cheap gauges may not be accurate and could read lower/higher than actual but the differential pressure should be reliable as the gauge will read the pressure evenly, even if slightly wrong.
If your compression is good and you want to test injectors, they will have to be taken to a qualified shop to do so. The extreme pressure of fuel being ejected from an injector nozzle is dangerous, will penetrate skin and cause severe injury.
   / BX2350 Running Rough and Smoking #6
I have a four cylinder engine in my L3700 and will give you the pressure values for that engine. I don't know which engine you have but the values for it should be very close.
My service manual lists an E2 and an E3 engine
Compression pressure when cranking with starting motor: E2 - 512 to 583 psi E3 - 470 to 540 psi (those are new factory values obtained with a professional gage.)
Allowable lower limit both engines: 370 psi.
Allowable difference among cylinders: 10% or less
Quote on procedure from manual:
1 Run the engine until it is warmed up
2 Stop engine and disconnect the 2P connector from the stop solenoid in order to inject fuel (Jinglish translates "in order to prevent injection of fuel?)
3 Remove the air cleaner, the muffler and all injection nozzles. (Tomas says muffler? I'd be tempted to try this without that step)
4 Set a compression tester with the adapter to the nozzle hole
5 Keep the engine stop lever at Stop Position (I don't have such a lever but disabling the fuel solenoid will do the trick)
6 While cranking the engine with the starter measure compression pressure
7 Repeat steps 4 through 6 with each cylinder
8 If the measurement is below the allowable limit apply a small amount of oil to the cylinder wall through the nozzle hole and measure again
9 If the compression pressure is still less than the allowable limit, check the top clearance, valve and cylinder head
10 If the compression pressure increases after applying oil, check the cylinder wall and piston rings.
Notes: Check the compression pressure with the specified valve clearance
Always use a fully charged battery for performing the test
Variances in cylinder compression values should be under 10%
So the key takeaways are that you need to make sure valve clearances are correct, your battery is fully charged and if oil boosts compression you have a ring or cylinder wall problem. If the oil doesn't help, you have a piston head top clearance, valve or cylinder head problem. A bent push rod will result in the top of the piston not reaching the required height in the cylinder to compress air to the required value. If your engine was running fine before the tip, depending on hours, your valves clearance should be OK but if you test low and oil doesn't raise pressure, adjust the valves and test again before you tear anything apart.
Here's hoping you see 500 or better across all cylinders and you can eliminate piston/cylinder/ring/head damage.
Recoverhill,
Thanks again for the wealth of information. I have the 3 cylinder diesel with a little over 250 hrs on it, but as you said, the values shouldn't vary too significantly. The step by step procedures are a great help as well, they seem rather straight forward and clear. Also, thanks for the warning about the injectors. I had heard as much previously, but it never hurts to hear it again. :) With the time change, I don't expect to have enough daylight to work on this until the weekend, still, I will keep you posted with my progress. Thanks again for the help.
John
   / BX2350 Running Rough and Smoking #8
Good luck with it and I sure hope you get satisfactory pressure on all three cylinders.
   / BX2350 Running Rough and Smoking #9
One procedural change to note...do not warm the engine due to the purpose and condition as that will exacerbate the problem. That is a procedure for normal conditions. Having said that, I realize you have already run the engine for a number of hours after the incident so its unlikely to cause further damage at this point. This caution is more of a note to others in the future.
Thanks again guys and thanks for the luck. I'll let you know how it turns out.
John
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
New Holland 499 Hydra - Swing Mower Conditioner (A50514)
New Holland 499...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
