BX2350 questions
   / BX2350 questions #1
nightscape
Troy,Ontario,Canada
Hi all...after a couple of weeks of minor use so far, I have a couple of things to state/ask.
I have found that the seat safety switch is much too sensitive. Just leaning from one side to the other causes the motor to cut in and out. There are places where you have to lean for weight distribution in order to cut, that makes it difficult when you are left with the choice of rolling over or not being able to keep the engine running, therefore not being able to go there at all.
Is there any way to lessen the seat sensitivity?
When backing up, letting off on the HST pedal, you almost need a neck brace. It snaps your head back violently every time. This is very annoying to say the least. This does not happen when letting off on forward motion. The brake is not on. I would prefer the pedal was short enough that you could fit both your toe and heal on it at the same time, that would make it easier to be gentle on the let up when moving in reverse. It is also uncomfortable having to bend your leg backwards to push on the reverse pedal in the first place.
A couple of friends have had their kubota's stolen over the last few months. Oue dealer says that there is a theft system that they can install. Is anyone familiar with this system? How does it work? Is it worth it? The dealer has not given me a price yet.
I have also been talking to them about a grill guard. I wanted to put on the silver one that comes with the BX24, but the dealer said he didn't know if it will fit the 2350. $220 for the regular orange one and $260 for the silver one with a 4 week wait he says.
I originally wanted to get a front snowblower for it as well, but the dealer shocked me when he said that the blower with the required hitch kits was going to be over $4000.
I don't know what to do now.
Okay , I'll stop talking.
   / BX2350 questions
   / BX2350 questions #3
Get more time with the HST pedals. I think in a short matter of time you will have a smooth transition in reverse. You do not want a pedal where your entire foot rests on it. The problem will be evident when you get onto some rough ground. If your reverse movement cannot be controled easily with your foot, I would suggest you have the tractor looked at, its very easy to control on HST. I have driven a BX22 which while different, would have some similarities.
   / BX2350 questions #4
   / BX2350 questions #5
Greetings nightscape, and congrat's on the purchase.
First issue, seat safety switch. There is no way to alter its sensitivity. When I cut my ditch, although leaning, I make sure I am at the edge of the seat, but positively maintain my full body weight on the seat.
Second issue, reversing the tractor. With practice you will develop better control of your heel. Try reversing with your toe and, assuring it is a smooth transition, then try to match that same synchronisity with your heel.
Third issue, theft deterent? Never heard of it. Contact your home owners insurance and make sure you are covered. What more can I say. Maybe the dealer has an alarm system for tractors.
Fourth issue, the silver grill guard. I have the silver "BX" grill guard on my BX2230, but it seems to me the orange one was $90 and the BX23 model, which was the other model current to the BX2230 was over $200. They were interchangable The BX24 is likely the same frame. Ask the dealer to get one and if it doesn't fit return it to Kubota.
Final issue, the front mount snowblower. Yup, more expensive because of the hydraulic lift as oppsed to a 3PH mount which, obviously, has its own lift capabilities. Once you've acquired the forward hydraulic lift, you can put on a broom or blade and you're good to go. That being said, I have the front mount and the local dealer quoted me $5k. I think I eventually paid a little over $3k for mine and I did buy 75 miles away in the end as the local dealer was taking me to the bank. My guy ran it all out, made another trip for the ballast box, another for the block heater and grill guard (sent 2 guys and they forgot to take the orange guard back), a fourth as I purchased the alternator upgrade and never heard any suggestion of travel time costs. Rest assured I'll be back to buy from him!
Call around the province and get some quotes. Don't tell the out of area dealers you have already spoken to your local rep as they have explicit instructions from Kubota Canada about staying within their respective jurisdictions. Technically, that just means they cannot solicit sales outside of their area, but if you go to them, alls fair in love and war.
Good luck /forums/images/graemlins/wink.gif
   / BX2350 questions #6
   / BX2350 questions #7
On the seat belt sensitivity, I agree with you. Pull the seat forward and check to make sure there isn't anything blocking your seat from coming down all the way. Last weekend, I checked, and sure enough, there were some wires that had come loose from their bindings and had lodged under one of the springs of the seat, preventing it from going all the way down. I retucked them with new binding and that seemed to help. If anyone knows of any other way to reduce the sensitivity, I would also like to know.
I paid about $100 for the orange grill guard, installed.
On the snowblower, did you get the FEL? Some folks have said that an FEL with rear blade are good cheap alternative. You can also buy a rear snowblower (you back up to plow the snow) for between $1,000 and $1,500, or get one used for as little as $500. I will likely be getting a rear snowblower to save the money, at least until I can afford a front one.
   / BX2350 questions #8
   / BX2350 questions #9
The reverse pedal sensitivity is a known issue, several people here have posted about it, and I've complained to my dealer as well, and even they have acknowledged that i'm not the only one unhappy about it. One story I've heard is that it's on purpose due to some litigation where someone backed into something. I suppose someone will come up with a fix for it.
And the seat switch can be disconnected entirely. Mine was so sensitive that I every time I stopped the engine would cough due to the weight on the switch changing. Also, I like to lean forward every now and then to check out what I'm about to destroy. The switch is at the right rear of the seat, and you'd need a jumper wire to bypass the switch. Of course, I'm NOT advocating you bypass a "safety" feature though... /forums/images/graemlins/tongue.gif
   / BX2350 questions #10
40ft Shipping Container (A50322)
40ft Shipping...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
