BX2350 loader joystick
   / BX2350 loader joystick #1
tbalt
kubota BX2230
Hi,
Does anybody know of a website that sells a kit for the FEL joystick on a BX2350? Also would you have a part number for the kit if you have ordered one?
I already have the YW247 loader valve and hydraulic lines but need the joystick assembly and linkages.
Thanks and sorry if this is the wrong place to ask this.
   / BX2350 loader joystick #2
what is YW247 ? Have you visited the local kubota dealer yet? If you don't have time, just go online to messicks and fill out the form to get the parts diagram for your BX. You should find all the parts you may be looking for.
   / BX2350 loader joystick #3
Not exactly sure what you're looking for but the kit for the valve and joy stick for the 50 and 60 series BXs is:
BX2324 Four Position Control Valve (LA243/LA240)
Compatible with Front Quick Hitch Implements
Not sure how you would have the valve on your tractor without having the joy stick with it???
Edit, you can order on-line from Messick's or Tractorsmart once you have the part or kit numbers you need.
   / BX2350 loader joystick #4
That was exactly my thinking.... but neverless- OP now has a direction to look for parts.
Let me start off by saying I have a BX2230.
I purchased the lines and valve for a BX2350 on Ebay and will be putting it on my tractor.
Already tried the valve as far as location and it will fit, but I still need to locate the joystick controls. Reason being I think this is a much cleaner setup then the bulky framing that comes off the side of a 22xx series tractor.
The YW247 is the valve ordered alone, complete part# YW247-00100
I'm aware that the BX2324 is the complete package but was hoping for a control kit without valve.
   / BX2350 loader joystick #6
See if this helps. It's a page out of the parts book for a BX1860. If you need something else, I'll see if I can find it in the parts manual. I had to copy it from the pdf file and past it into Word.
Thanks, I have a website with the parts break down just like your pic. Problem is if I order all the parts seperate it comes to almost $400.
The dealer has the complete kit BX2324 for $636, Kubota seems to sell a complete kit for a big discount over ordering the parts seperately, just wish I would have known that before getting the valve. :(
Hopefully I can find someone on Ebay that just needs the valve and lines, then I will just buy the complete kit.
   / BX2350 loader joystick #8
Take two. The above doc isn't all the parts you probably need. I didn't spend the time to figure out the differences between the various diagrams so hopefully it contains all the parts you need.
Grundfos Centrifugal Pump (A50121)
Grundfos...
377054 (A51573)
377054 (A51573)
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2017 Nissan Sentra Sedan (A50324)
2017 Nissan Sentra...
