My new BX2350 with 60" MMM, Loader, and Grass Catcher was delivered yesterday. I took the loader off and mowed the lawn and it did a geat job. But when I went to put the loader back on, I had problems attaching the hydraulic lines. I was not able to connect the yellow and white lines because the pressure was too high and I could not apply enough force to overcome the pressure in the hoses. I called the dealer and they sent out a service technician. The technician was able to connect the yellow hose with some difficulty, but not the white one. He then pulled out a special tool, a 1/2 inch piece of hardwood dowling, pushed it into the end of the white hose, and then pushed the hose with the dowling inside against the arm of the loader, which caused the pin inside the hose to push in, releasing some hydralic fluid out of the hose and reducing the pressure. Then he easily attached the white hose now that the pressure had been reduced.
He then told me this was a typical problem with the new BX tractors. The hydraulic lines remain pressurized when they are detached, and they are difficult to reconnect. He said there was nothing I could do, other than release the pressure in the hose before I can reconnect it.
Is anyone else having this type of problem? Am I doing something wrong when I detach the loader. Is there some easy way to relieve the pressure in the hoses to make it easier. I got the impression that it was easy to take the loader on and off, and I had planned on taking it off when mowing the lawn, but now I am having second thoughts.
Thanks for your help.
Ken....
Ken....
