stu1951
This is very strange!
Took loader off tractor and was working fine
Put on front mount snowblower to test and get ready for the snow.
The Hydraulic Shoot rotator goes only in 1 direction.
I reversed the 2 center quick disconnects and it goes in the other direction.
Then I connected the shoot hoses to the outer 2 and it worked in both directions.
Then I used the 2 center for raising the front hitch using the left to right lever and it went up and down.
Then I switched the lines on the center 2 valves and it would push down the snowblowerand raise the tractor but in that spot it would no release the pressure to let the blower go back up
Any ideas? Whats going on?
