BX2350 hour meter
   / BX2350 hour meter #1
dgraves49
tecumseh michigan
kubota bx2350
Can any one tell me if it is possible to have a new dash panel hour meter set to match the hours showing on the one being replaced?
Mine is currently mostly black but can be read if you try hard.
   / BX2350 hour meter #2
Most hour meters are tamper proof. If electric hook it up and let it run 24/7 if not to many hours on it.
   / BX2350 hour meter #3
Old timers would just write the actual hours / miles on the dash or under the hood. I've seen truck with stickers on the dash stating the mileage before he replacement gauge.
   / BX2350 hour meter #4
:thumbsup:
   / BX2350 hour meter #5
A friend had to have their digital odometer replaced on a car they bought in Canada (Kilometers) to show miles when they brought it back to the states. It was quite a spectacle, a Dodge representative flew down with the new odometer with the mileage preset on the new gauge that was indicated when the request was made. Of course my friend continued to drive it for about a month till Dodge got it all together. Anyway the Michigan rep watched as the dealer installed the new odometer. Dodge didn't trust a dealer to install a new odometer and preset the mileage, guess this says something about Dodge dealers.
I guess this wouldn't be much of an issue on an older out of warranty tractor so a new gauge could be bought and installed by the owner. A note could simply be made in the owners manual stating the original hours on the old gauge and date it was replaced OR if the hours count when the key is on, just hook it to a battery and let it run 24/7 till the right hours are indicated, then install it. Personally I prefer a gauge that count revolutions of the engine and then calculates hours based on 540 PTO speed of the engine. Hours as idle just aren't the same as working hours.
   / BX2350 hour meter #6
I had to replace the aftermarket digital hour meter in my F250 at the 12 year 2100 hour mark. Think the batteries went dead. I called manufacture as old hour meter was not on website. He informed me of suggested replacement, and said this is programmable, just use buttons to program old number, and go. Philip.
HAY KING RENOVATOR (A52472)
HAY KING RENOVATOR...
Dual/Moyno Pump System (A50121)
Dual/Moyno Pump...
New Holland 479 Haybine (A50774)
New Holland 479...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
